6th Gen ('00-'05): Coilover installation!
Old Aug 29, 2014 | 05:22 PM
HIxArsenaL's Avatar
Exclamation Coilover installation!
I purchased ZZP wbody coiovers, im trying to go the DIY route but i dont have any clue of how to take out the stock suspension. is there any write ups of how to install coilovers? can someone point me into the right direction to installing coilovers?
Old Sep 7, 2014 | 12:51 PM
Jokers1995's Avatar
What exactly do you mean by taking out the factory suspension?
Old Sep 7, 2014 | 05:34 PM
Your doing coil overs? Nice, they are an odd bird to find for our cars, off hand don't remember other members who have done them. Your bound and determied to get your sweet Monte lowered one way or the other aren't you? That's the spirit, never give up, never surrender. To bad about the dumb sh*ts blowing you off on your bagged setup. bad news travels faster than good news. That would have been extra sweet to have had done on your Monte.
If you remove your oem struts as a whole unit, I would imagine your coilovers should install exactly in reverse of the oem struts you removed. Do they look so different than the factory struts that it is raising a question? I would think that if they come preloaded the swap out would be fairly easy. 2 bolts at the bottom and 3 bolts for the top. But I could be wrong, just not famaliar with any quirks the coilovers may present.
Old Aug 14, 2021 | 06:50 PM
blkhwk7215's Avatar
how many clicks do you have your coil overs set on
I have a 2004 sc with the zzp coil overs what do you suggest on the settings I have on 13 now n its hard on bumps
wht02monte
May 3, 2021 11:24 AM
bfenty
Aug 11, 2014 11:56 AM
slowguy
May 5, 2014 11:33 AM
D_Spear
Mar 17, 2013 06:51 PM
2003supersport
Feb 18, 2009 07:12 PM
