6th Gen ('00-'05): Brake Upgrades
Old May 1, 2015 | 12:08 PM
GTHSS's Avatar
Originally Posted by zjerry
I installed 2002 Camaro calipers & pads on my 2005 Monte Carlo SS
The top pad is stock Monte bottom pad is Camaro..
You have to drill & tap the caliper brackets..
Originally Posted by ZIPPY02
That is the ticket what Z Jerry did, upgrade to the 2000-2002 Camaro front brake calipers. I have done the same, much better braking when you really need it. They are all over at the junk yards, Firebird , Camaro calipers, bet you can get them for $25 a pair. The rear rotors we have are the biggest set we have available, think the Pontiac GP guys put our Monte rear calipers / rotors on their cars. As far as rotors go, hit eBay up for some drilled / slotted, they can be had for cheap. See the link below, I would buy new rotors all the way around, get the F-body front calipers, buy some good brake pads for them and also some new pads for the OEM Monte Carlo rear calipers.
See this link, these will be plenty fine and for a super price too...
Front Rear 4 Performance Drilled Slotted Brake Rotors and 8 Ceramic Pads M040537 | eBay
I have Bendix ceramic pads, AC Delco rotors (all bought from the "performance" section on RockAuto.
For the stainless lines, I'm using the kit sold by Goodridge, zero issues so far.
Hey thanks guys. Sorry I did not see and reply to the messages in March l67ss, Jerry, and Greg! Thanks for the Info.
As for the color, I still have the stock calipers. I painted them Electric Blue but I think I am going to try Hugger Orange or SS Red when I install the Camaro calipers.
Old May 1, 2015 | 03:18 PM
Brendocee55's Avatar
Willing to sell those calipers when you put new ones on?
Old May 1, 2015 | 06:52 PM
GTHSS's Avatar
Sure thing. I will IM you when I make the swap. I will check a few junkyards next week to find the camaro brake calipers. The swap should be soon after.
Old May 1, 2015 | 07:26 PM
You need the F-body bracket for the f-body calipers..
You have to drill the F-body Bracket because the W-body uses a bigger bolt then the F-body..LOL
I used my stock rotors you can use stock brake lines all you need to do is bend the brake line bracket to give the line slack.
you need for drill/tap and parts you need to get for the swap. the pic is of a F-body bracket.
I installed 2002 Camaro calipers on my Monte sunday 12/30/2012
Love the looks an the stopping power , Its not hard to do, nice mod..
Old May 1, 2015 | 09:24 PM
Does it have to be the v8 model camaro or trans am? Or can it be the v6 version as well?
Old May 1, 2015 | 10:52 PM
All are the same calipers.
Old May 1, 2015 | 11:24 PM
Hmmm i might have seen a f body at one of my local junkyards. So just the brackets, calipers, and tap the brackets from the f body? Then bend the brake line bracket? Doesn't seem too bad
Old May 2, 2015 | 07:00 PM
NYGiantsfan's Avatar
Did u get only the fron brake lines or all around?
naiku
Feb 5, 2013 03:03 PM
LkErieMonte04
Nov 4, 2011 05:12 AM
sfritz85
Apr 22, 2011 03:06 PM
bob442
Jan 20, 2010 09:29 PM
88ss408
Apr 16, 2007 05:59 PM
