Brake Pistons
Old Nov 7, 2009 | 12:42 PM
04TurboSS's Avatar
Awaiting Email Confirmation
Default Brake Pistons
Is there a way to check if the pistons on my new f-body brakes work before i actually put them on my car? I got them from the junk yard and they are pretty rusty. This may sound kinda stupid, but i figured id ask.
Old Nov 7, 2009 | 06:29 PM
RocknSS04's Avatar
They come out pretty easy. Clean things up and put them back together. Just make sure you use brake cleaner or/and some brake fluid to do it. Good time to grease the slider pins, also. REAL easy to do.
Old Nov 7, 2009 | 06:31 PM
RocknSS04's Avatar
You know they don't just bolt up, right? You need bushings around your bolts OR you drill and tap the hubs for the larger 12mm? bolts.
Old Nov 7, 2009 | 08:22 PM
04TurboSS's Avatar
yeah i know that, i was gonna have them tapped. how do the pistons come out? i tryed but i thought i was breaing the caliper. ive cleaned them up real nice and thats just the last step.
Old Nov 8, 2009 | 12:13 AM
nemesis's Avatar
2009 Monte Of The Year
air compressor is the best way to take out. there's a thread on clubgp on how to remove the pistons. i'll try to find it for you. if you have air compressor you can try this method cuz it does works. i tried it at my friend's, cover up all the openings tightly on the calipers and stick the air compressor nozzle in the slot where the banjo bolt go in and squeeze the trigger. if you get lucky both will pop out, other wise only one come out. repeat the same thing to get the other one out.
Old Nov 8, 2009 | 12:21 AM
04TurboSS's Avatar
my boyfriend has one at his house. ill give that a try tomorrow. itll be great if this works out because i got them for so cheap lol
Old Nov 8, 2009 | 12:29 AM
nemesis's Avatar
you did get the banjo bolt from the fbody, anti rattle clip (it's the clip go in the middle of the caliper. 2 total) and the 2 clips holding the pads (total 4 clips)
Old Nov 8, 2009 | 12:51 AM
04TurboSS's Avatar
yeah, im pretty sure i got all the bolts and clips that came with them.
Old Nov 8, 2009 | 03:38 AM
nemesis's Avatar
you're good then
Jordanshedd5
Jan 25, 2014 04:02 PM
JohnieWalker305Blue
Jan 17, 2012 08:18 PM
MonteLSV6
Nov 2, 2009 06:09 PM
Enzo354
Dec 2, 2008 06:45 PM
f16fixr
Oct 18, 2008 04:15 PM
