Loose pistons?
Old Jan 25, 2014 | 04:02 PM
Jordanshedd5's Avatar
Default Loose pistons?
Okay, so I'm in the middle of a head gasket replacement. I have a 2000 monte LS with the 3.4L all stock, 135,xxx miles. I have got everything pulled apart and there was coolant in cylinders (hence why im doing the job). When i soaked it all up, it seems like the pistons are loose. Like I can move them side to side a little more than the thickness of a piece of paper. Not much but they move. Are they supposed to super snug or have a bit of play for when they heat up and expand?
Also how do i check for rocker wear and wear on the lifters (rods with rounded ends that push on the lifters? Do i need to?
Thanks all!!!
JohnieWalker305Blue
Jan 17, 2012 08:18 PM
04TurboSS
Nov 8, 2009 03:38 AM
MonteLSV6
Nov 2, 2009 06:09 PM
Enzo354
Dec 2, 2008 06:45 PM
f16fixr
Oct 18, 2008 04:15 PM
