Ported Heads and Pistons????Camshaft
Old Jan 14, 2012 | 08:44 PM
JohnieWalker305Blue's Avatar
Default Ported Heads and Pistons????Camshaft
20004 L67 Supercharger What is a good setup for Ported HEADS and PISTON size just blew head gasket so might as well spend all of my Blue Label money Also need a Cam suggestion and did anyone do the ZZP rockers
Old Jan 17, 2012 | 02:17 PM
monte07's Avatar
there is some here that have a supercharged monte's. as well as a fully built one i like that bumpin did i am not sure what his full screan name is. his monte has a good list of things he did as in engine trans and a supercharger i forgot what he did. but there are whole sections about the supercharged 3800 on rebuilding them and the good stuff they did.
Old Jan 17, 2012 | 02:18 PM
VS Cam is good for boost.
If you cam, don't rocker. You shouldn't have to worry about swapping pistons.
Old Jan 17, 2012 | 08:18 PM
zipper's Avatar
The XP cam is also highly favored with the L67 crowd. ZZP is probably going to give you the greatest variety of things to do to your L67.
godfather202
Sep 13, 2014 04:58 PM
zk6216
Aug 17, 2011 09:36 PM
Enzo354
Dec 2, 2008 06:45 PM
