2002 monte ss squeaking
Old 10-13-2006 | 12:00 AM
gtpfastboy's Avatar
Default 2002 monte ss squeaking
hello guys i have a 2002 monte carlo and it squeaks in the front every time i hit a bump.
it only squeaks in the front. do you guys have any idea what that could be?
Old 10-13-2006 | 05:25 AM
mickey's Avatar
Default RE: 2002 monte ss squeaking
we had a old rustang for the wife that did this also.
it was the front struts on it. but i was told to check the springs to see if they were hitting on anything also.
Old 10-14-2006 | 02:00 AM
FULL_MONTY's Avatar
also wouldn't be a bad thing to hit it up with a greese gun if you have one. just as a general maintainance thing.
Old 10-30-2006 | 04:23 PM
04 Intimidator's Avatar
Try to push down on the front end to reproduce the squeaking. If you can, open the hood and check where it's coming from. Look for excess wear in the area.
Old 10-31-2006 | 03:39 PM
rchurch's Avatar
If it's hard to tell exactly where the squeek is coming from you can use an old mechanic's trick: Cut a piece of hose about 3 ft long (old water hose works fine) and hold one end up to your ear while moving the other end to different spots. You can hear the noise easily and pinpoint exactly where the noise is.
Old 11-01-2006 | 06:14 AM
2006MonteCarlo's Avatar
rchurch is right that works every time
jimbo7
05-30-2011 04:13 PM
04MonteLS
02-22-2011 12:53 AM
iceman56607
12-27-2010 08:21 AM
joedaslik
11-14-2009 03:46 PM
echoingvoid
09-20-2009 02:08 AM
