2002 monte ss squeaking
Old Oct 12, 2006 | 11:00 PM
gtpfastboy's Avatar
Default 2002 monte ss squeaking
hello guys i have a 2002 monte carlo and it squeaks in the front every time i hit a bump.
it only squeaks in the front. do you guys have any idea what that could be?
Old Oct 13, 2006 | 04:25 AM
mickey's Avatar
Default RE: 2002 monte ss squeaking
we had a old rustang for the wife that did this also.
it was the front struts on it. but i was told to check the springs to see if they were hitting on anything also.
Old Oct 14, 2006 | 01:00 AM
FULL_MONTY's Avatar
also wouldn't be a bad thing to hit it up with a greese gun if you have one. just as a general maintainance thing.
Old Oct 30, 2006 | 03:23 PM
04 Intimidator's Avatar
Try to push down on the front end to reproduce the squeaking. If you can, open the hood and check where it's coming from. Look for excess wear in the area.
Old Oct 31, 2006 | 02:39 PM
rchurch's Avatar
If it's hard to tell exactly where the squeek is coming from you can use an old mechanic's trick: Cut a piece of hose about 3 ft long (old water hose works fine) and hold one end up to your ear while moving the other end to different spots. You can hear the noise easily and pinpoint exactly where the noise is.
Old Nov 1, 2006 | 05:14 AM
2006MonteCarlo's Avatar
rchurch is right that works every time
jimbo7
May 30, 2011 03:13 PM
04MonteLS
Feb 21, 2011 11:53 PM
iceman56607
Dec 27, 2010 07:21 AM
joedaslik
Nov 14, 2009 02:46 PM
echoingvoid
Sep 20, 2009 01:08 AM
