[6th gen] Door squeaking?
Old May 27, 2005 | 04:17 AM
04MonteLS's Avatar
Default [6th gen] Door squeaking?
My 04 MC's driver door would squeak a little bit when I opened it all the way. It got on my nerves, it's a new car, not supposed to do that. So I stopped by the local auto part store and picked up some Liquid Wrench L4. It's a foaming penetrant and lubricant made with CERFLON, whatever that is. Sprayed some on the door brackets, squeak is gone!!
Old Oct 24, 2006 | 02:25 AM
nero14's Avatar
Default RE: [6th gen] Door squeaking?
WD40?
Old Dec 3, 2006 | 12:52 AM
djizzle's Avatar
white lithium grease is better because it last for like ever. it leaves a white residue but thatz how u kno itz there. lub all ur hinges and rubber parts and u wont squeks for months..
Old Dec 3, 2006 | 04:07 PM
04 Intimidator's Avatar
WD-40 is a very temporary solution as is Liquid wrench. You will want to get some grease in there and that will last longer. You will still need to do this every so often.
Old Dec 3, 2006 | 04:08 PM
Also check for premature wear on the door bushings. That can occur if the doors are slightly off or people slam your doors.
Old Jan 21, 2010 | 09:23 PM
Also try lubing up the door spring too.
My driver's door was squeaking like crazy and bugging me. I used some spray on white lithium grease on the hinges and the piece that holds the door open also.
Door opened and closed easier. But still sqeaked like crazy. I sprayed the door spring and the noise went away.
Old Jan 22, 2010 | 12:05 AM
Wilco's Avatar
X2 on the white lithium grease. Once on the hinges it's just a matter of redoing yearly.
Old Jan 22, 2010 | 12:14 AM
jimbo7's Avatar
whenever it rains then drys out again my driver door on my lumina squeaks horribly. i carry a can of triflow in my car now.
Old Jan 22, 2010 | 09:59 AM
I use gun oil. Same stuff on my ISS too haha
Old Jan 28, 2010 | 05:02 PM
werewolf-odst's Avatar
that noise was getting my nerves also. but i thought it was because of the accident or accidents and it wll squeck till i get new doors.
