2000 SS how to replace rear wheel hub?
Old Jun 5, 2011 | 03:44 PM
shad420w's Avatar
Default 2000 SS how to replace rear wheel hub?
error. no need
Old Jun 5, 2011 | 08:14 PM
Dunno how much this will help you.
http://www.paulstravelpictures.com/GM-Wheel-Bearing-Hub-Assembly-Replacement/index.html
Sometimes they can be stuck on there pretty well.
Old Jun 5, 2011 | 08:27 PM
Sometimes you have to use air hammer or big hammer to help remove hub..
Old Jun 6, 2011 | 12:53 AM
kingreyna's Avatar
Go to Autozone and rent a hub puller. I just changed out both fronts on an 02 LS and one came off easily the other did not. I also used the site that BlackSheep put up.
Good Luck
Old Jun 7, 2011 | 03:13 PM
Daymack's Avatar
Rohan,
I feel your pain. I replaced the rear hubs a couple of weeks ago. A wheel hub puller will not work since there is nothing in front to push against.
For the first hub I ended up taking off the strut from the knuckle and also removed one of the other bolts that is holding the knuckle in place. I could then rotate the knuckle and was able to use a hammer to hit the hub from behind and knock it out.
After thinking about an easier way to get the second rear hub off, I came up with using a steering wheel puller.
From behind the hub (where you plug into the sensor), put the steering wheel puller in between the back of the hub and the bolt that is holding the strut on and then use one of the bolts that held the hub on and screw it into one of the bolt holes (in the opposite direction from which you removed the bolt). Make sure the center bolt on the puller is on the back of the hub and begin turning the center bolt on the puller until the hub comes out. This was much easier than using a hammer to get it out.
The emergency brake cable will still be attached to the hub. There are two screws to take off .
I hope this helps.
Radagast the White
Aug 17, 2014 10:52 AM
2002 SS
Mar 10, 2014 09:21 AM
Chris s
Jan 29, 2013 11:11 AM
zillatattoo
May 10, 2012 10:24 AM
aaronkt
Dec 11, 2008 04:54 AM
