Which hub assembly to replace?
Old Dec 10, 2008 | 01:22 PM
aaronkt's Avatar
Default Which hub assembly to replace?
Hey all!
so you know the story as i have read on here a few times. ABS light is on. It has to be one of the sensors on the hubs. I have replaced the rotors once and changed the pads 2 times in the past year and half. Is there any way to tell which hub is bad?
thanks in advance!
Old Dec 10, 2008 | 03:24 PM
Default RE: Which hub assembly to replace?
is the trac off light on as well?
if your pulling a code, you should be able to determine which tire.
Old Dec 10, 2008 | 04:47 PM
aaronkt's Avatar
no, the trac light is not on, just the ABS light. I don't have a code reader. I called Advanced Auto parts and they dont have the reader with the software that will do ABS stuff. Any other suggestions?
Old Dec 11, 2008 | 04:54 AM
bowtietech's Avatar
First you need to have someone scan your car to determine what ABS trouble code is stored. You cannot just assume its one of the wheel speed sensors as there are other things that can cause the ABS light to come on.
Xraycatj
Mar 26, 2011 07:43 AM
uptownfam
Nov 23, 2010 05:04 PM
teamfbody
Apr 12, 2010 10:18 PM
orthokneepa
Sep 8, 2009 09:19 AM
rgant_19
Aug 14, 2009 08:13 AM
