'02 SS lowered 2"
Old 04-04-2005, 11:54 PM
Default RE: '02 SS lowered 2"
ooooo SEXI!!!
Old 05-22-2005, 04:46 AM
ORIGINAL: rchurch
In November I posted that I had lowered my 02 SS and that I would get some pics of it. I have the pics, but they are too large to post here. I don't know how to make them a smaller file. If anyone would like to see them, e-mail me at rchurch@randallchurchllc.com and I will send them to you. Just a recap:
lowered 2" ront and rear
Eibach high performance springs
KYB gas struts
8.5" x 17" rims
255 - 45 Z rated Dunlop tires
wow, the 17's look small. Did you get the GR2 or AGX struts? The GR2's are silver, AGX are red.
Old 05-24-2005, 12:55 PM
rchurch's Avatar
They are the GR2's, because they are silver. What is the difference? I didn't even know they had different ones. I guess I should research better before spending the money.
The 17's do look small, but I wanted to put a tire on it that still had a good size sidewall because I didn't want to lose the ride quality. I felt if I put 20's on it the tires wouldn't have any sidewall and the ride would really suffer.
Old 05-25-2005, 03:01 AM
ORIGINAL: rchurch
The difference between the GR2's and the AGX is that the GR2's are basically a slight upgrade from oem shocks/struts, they can handle a slight drop, I believe an inch or so at most, but I wouldn't go much lower than that as they are not built for that application. The AGX have adjustable dampening, which is lovely! I had them on my 94 Accord and it was nice cause when I loaded up the family, I could set the stiffness to soft so we could get the comfortable ride, but when it was just me and I wanted a more responsive/sporty feel to it, crank up the stiffness and I was ready for the auto-cross! The fronts are adjusted with a screwdriver(provided) under the hood at the shock tower, from 1-4, 1 being the softest, 4 being the firmest. The rear one's have a **** on them, marked 1-8, with 1 being the softest. To adjust those, you simply reach under the car and grab the **** at the base of the shock, turn to the setting you desire, and you're on your way.
The AGX are a little pricey, I believe I paid $340 for mine, shipped, but they are well worth the money! That being said, I wonder if they have an application for the Monte?
I totally understand your reasoning, makes alot of sense. It's that reason that I went with 17's on my Civic instead of 18's. I am only getting 18's for the Monte cause I would be able to get a 45 series tire, which is about the lowest I wanna go on any car, and because it fills out the wheel well a little more. I may drop it a little bit, but if I do, it's gonna be a modest drop and most likely using Eibach springs.
Old 07-27-2005, 11:51 PM
Help!!
I lowered my 2005 Monte SS 1.8" using Intrax springs. Now I ahve a bad vibration under acceleration around 45-60mph.
I had this same problem with my 2001 SS.
Any solutions??
THANKS
Old 07-28-2005, 12:06 AM
ORIGINAL: Smilinmike2001
Help!!
Any solutions??
THANKS
Did you get an alignment?
Old 10-05-2005, 02:14 AM
Ok Guys I'm New Here
I have a question about rear suspension camber adjustment (THRUST ANGLE). How do I do it?
Thanks, Geo
Old 10-13-2005, 04:23 PM
so how is the ride with the springs?
I have also looked at redong mine to get it to sit a bit lower. But really would like to keep the ride and would like to get the antiroll bars for it eventually
Old 10-14-2005, 04:05 PM
rchurch's Avatar
The ride with the Eibach's is great. It is a bit stiffer, but I always thought the originl ride was too soft, especially for a car called "SS". At first the stiffer ride was very noticable, but it didn't take long to get used to it. I was also concerned about the stiffer ride creating rattles, but that hasn't happened.
The car is dropped about 2". It really makes it look better, more sports-car like. I have parked next to stock height cars and you can really see the difference.
The 17" rims are kinda small looking, which I didn't expect. I wish now I would have gone with 18"s, but nothing bigger. I have about 27,000 miles on the tires now and will replace them in the next few months, at about 32,000 - 35,000 miles. They are 255-45's and I am going to look at a different size, maybe around a 265 or 275/50 or 55 if they will fit. I want the tire to fill the wheelwell a bit more and wouldn't mind a bit wider. They are the Daytona Z rated, and I want a more aggressive-looking tire. Any suggestions would be appreciated. We get alot of rain here, so a good wet/dry tire is necessary.
Old 10-14-2005, 04:20 PM
i only buy the BF good ritch when i can But i have to replace the Z rated ones i have on mine now. They are tore up thanks to a lot of playing on eh Auto bond.
But i have seen the BE goodritch Traction Ta they had great reviews on them but they were like h or v rating instead of the Z
Honestly unless your going at speeds over 100 you really dont need but that is all my own opion on that one. The compound in them is way to soft .
but they are fun and great to know that you have it when needed.
also good years or Dunlops seem to make pretty good tires . But i have never ran Dunlops on my montes i have on the Harley but that is about it.
montecarlo01ss
04-12-2009 08:02 AM
2003supersport
02-04-2009 09:15 AM
Scream
01-22-2009 01:50 PM
Jay84SS
08-12-2008 08:57 PM
White05LT
08-30-2006 10:51 AM
Quick Reply: '02 SS lowered 2"
