What did you do to your Monte Carlo today?
Old Nov 10, 2012 | 07:50 PM
  #351
zzapultimate's Avatar
Originally Posted by DE02Carlo
I put about 60 miles on it and put it away again.
Your intimidator looks amazing man... sooo clean
Originally Posted by zjerry
I redid my speedo today , I like this one better..
That looks great Jerry! Is that a sticker? Where did you get it?
Old Nov 10, 2012 | 08:00 PM
  #352
Thank's ,I got it from http://www.fastdecals.com/shop/misce...l-sticker.html ,custom letter decal
you can get 10% off using Coupon Code FAST
Old Nov 10, 2012 | 08:44 PM
  #353
aussiek2000's Avatar
Got my 4 "new to me" wheels mounted up this morning. And it proceeded to break tonight. Go to leave my parent's house and the key wont turn. Needs a lock cylinder. Got to wait until Monday to get parts though, and then I have the pleasure of drilling the old one out.
Old Nov 10, 2012 | 08:49 PM
  #354
Dale3goodwrench's Avatar
Monte Of The Month -- March 2009
I did this today.
Attached Thumbnails What did you do to your Monte Carlo today?-dscf0219-1024x768-.jpg
Old Nov 10, 2012 | 09:06 PM
  #355
Originally Posted by Dale3goodwrench
I did this today.
out with the old....... you gonna be ready for the Monte Nats in Richmond next year.........
Old Nov 10, 2012 | 11:17 PM
  #356
Enzo354's Avatar
STILL SLOW
That one looks great, looks factory.
I took out my spark plugs today.
Old Nov 11, 2012 | 12:10 AM
  #357
bizparr's Avatar
Had some shop brand glass pack mufflers put on my car the other day.. previously I was running with a single 21" glass pack in place of my resonator and straight pipe to a Y out the back. It sounded great with the 3400, rumbly idle with absolutely no rasp at high RPMs. But, the drone was killing me on highway trips.
Current setup is one 21" glasspack and a Y pipe out to 2 12" glass packs. Call it cheap, or whatever you will. I just cant justify spending 100$+ on namebrand mufflers that don't sound as good. I much prefer the sound of glasspacks, in my case it gives me a very tame low end, but still makes lots of noise when you mash the pedal. The idle isn't as rumbly now but it has that pleasant deep tone that puts a bit of pressure on your ears. Again, I do have the 3400. Different firing orders and therefore different engine noises, what sounds good for me may not for most of you :\ .
Sorry for the long post! Kudos to those that have the patience to read it.
Old Nov 11, 2012 | 07:51 AM
  #358
Thank's ,Brock I was going to leave the Limited Edition part there , But some people where whinning about my monte not being Limited So I covered it up with Supercharged .. I like how it turned out One of a kind..
Old Nov 11, 2012 | 05:11 PM
  #359
monte07's Avatar
i got gas checked aire pressure in the tires and checked the fluid. i am going to be off tomorrow and goting to top off my radiator fluid. it looks like i had a air buble that finnally worked its way out of my system. it was cold yesterday and this morning and i used my heater. it probably worked the rest of the air bubles out. i didnt see any leaks when i got off work the past couple of days. it was running a little warmer than usual. but not to wory about. just a little low due to changeing the fluid.
Old Nov 12, 2012 | 07:44 AM
  #360
DeanMachine's Avatar
Yesterday I washed, waxed, and detailed inside/out in prep for winter weather, plus replaced my slowly dying courtesy/step lights with red LEDs. Looks pretty neat
