Painting Chrome-Plated Plastic
Looking for good recommendations and any tried-and-true methods for prepping chrome-plated plastic for paint and/or a good primer and paint products to use on chrome-plated plastic. Last time I tried, the chrome plate was like sanding ice and would not take the sandpaper very well. The goal is to avoid premature peeling and chipping.
Peeling / chipping of paint over plastic chrome is common. IMO it's always attributed to poor prep.
The most through approach would be to sand the chrome off to get it to base plastic. Leave the plastic a bit rough and use a quality plastic primer, followed by your paint.
IMO that's a bit overkill unless the part needs to really stand up to rough conditions (lots of flex or a spot at the front of the car where it will get hit with debris). If not for either of those conditions, I'd sand it down enough to get rid of the mirror shine, leave it a bit rough to add mechanical grip and then prime it.
If it's hard to sand, have you tried going to wet sanding? I'd probably start with 600 grit wet and relatively high pressure just to get into that top surface.
I'm toying around with the idea of painting the front upper grill trim black. I would need it to adhere well so it doesn't chip easily - I don't want it to turn into touch up galore in 2, 3+ years. I had the dealership that did my front end repaint in 2012 also paint the fog light bezels black and I like how those look. Obviously being a body shop they were able to prep properly.
Oh yeah, trust me, that'll happen if I do. I shot a couple coats of clear over the Niteshade when I smoked my back-up lights a while back. That added protection helps a lot and paint tends to fade significantly faster without clear on it.
6th Gen ('00-'05): Start painting rocker panels
owens91
Apr 2, 2016 09:19 PM
z34_98blue
26
Aug 11, 2010 06:01 PM
