Paint question
Hey everyone, so I have the day off today so I figured I would paint my engine cover. Does anyone by chance know if duplicolor or any other pant brand had a paint that is close to victory red or should I find someone who can take my paint code and mix the paint for me?
You have to buy special paint because it needs to be able to withstand the heat of the engine. Go down to your local auto store and buy GM Red and make sure its the spray can that says like 500 F so you know it can hold in the temperatures.
Will I get any difference in finish if I go with high temp paint or non high temp paint?
I did it to my 06 cover years ago before I just ditched the cover if you have an 06 LS4 the cover just snaps off without removing the oil cap pull straight up. Duplicolor does make a victory red spray paint now. As mike said preparing th plastic is everything. Make sure it is CLEAN and dry prior to painting
Post pics when you are done. Myself I just diched the cover and painted the intake manifold high heat krinkle red and the valve covers high heat krinkle black, painted the Ignigtion coils red and the coil brakets gold
