Paint question
Hey everyone, so I have the day off today so I figured I would paint my engine cover. Does anyone by chance know if duplicolor or any other pant brand had a paint that is close to victory red or should I find someone who can take my paint code and mix the paint for me?
You have to buy special paint because it needs to be able to withstand the heat of the engine. Go down to your local auto store and buy GM Red and make sure its the spray can that says like 500 F so you know it can hold in the temperatures.
I got you. Now I have another, probably stupid, question. I have never had to take off my engine cover...how would I go about doing so? haha. I have the 06' monte SS
The cover doesn't get so hot to require engine temp paint. You will be fine.
Take off your oil cap and pull the cover. You won't break it but it can be stubborn. |
(Post 542817)
Finish is all about prep and how well you sand between coats. Just don't mix brands for paint and clear
I did it to my 06 cover years ago before I just ditched the cover if you have an 06 LS4 the cover just snaps off without removing the oil cap pull straight up. Duplicolor does make a victory red spray paint now. As mike said preparing th plastic is everything. Make sure it is CLEAN and dry prior to painting
(Post 542830)
Post pics when you are done. Myself I just diched the cover and painted the intake manifold high heat krinkle red and the valve covers high heat krinkle black, painted the Ignigtion coils red and the coil brakets gold
Here's a diagram of the LS4 engine cover for 06+. There's three of those pins (#3) that the cover snaps onto and is held down with.
http://www.tonkinonlineparts.com/ima...20MW00-044.JPG |
