license plate bolt holes
Old Jun 27, 2011 | 01:35 PM
dougiefresh15's Avatar
Default license plate bolt holes
Two of the holes in the rear bumper are stripped and you cant get to them from the back so all the license plate does is rattle..anyone have an idea of how I could fix this problem?
Old Jun 27, 2011 | 01:48 PM
Try googling for something called a "Nutsert"
You should be able to find something to add in the hole that will give your license plate something to grab. Unless you want to fill the holes with a 2-part epoxy that after it hardens you can tap for new screws.
Old Jun 27, 2011 | 01:51 PM
Jester_20's Avatar
you could try some "thread tape" on the bolt and that'll make the threads a little thicker so they may grab a little more. That's what i'd try, if it doesn't work, you're not out anything . . .
Old Jun 27, 2011 | 02:11 PM
Thanks!!
Old Jun 27, 2011 | 03:08 PM
On my Monte, the rear license plate mounts screws go into square plastic/nylon inserts. You get replacements usually in a license plate bolt kit.
When I got my Monte, I did not feel my plastic inserts held properly (I think part of them was cracked from another owner over tightening). I just busted them out using a cloth to protect the paint and strategic prying on the original ones (they busted BEFORE popping out). Just popped new inserts in. I think less then $5 for the kit with the inserts, new screws and cover buttons.
Franks 03SS's Avatar
2011 Monte Of The Year
Old Jun 28, 2011 | 09:45 AM
RickAKATed10's Avatar
Photobucket
I googled nutsert, and got some pretty wild sites, Mike. My boss isn't happy either. :p
Old Jun 28, 2011 | 09:58 AM
LOL real nice :P
Old Jun 28, 2011 | 11:39 AM
I was going to suggest that too. But I lucked out when I needed one. The guy at the parts counter at a local dealership gave me a few free. He said he didn't even have a part number for them. Said they always keep some around in case.
Cheap is good. Free is better.
Old Jun 28, 2011 | 12:20 PM
I think I won'y have to worry about those plastic pieces for a LONG time (so maybe I have a ton free). I really like the kits with the snap on buttons that hide the screw head. Since I rarely need to replace the nylon inserts I don't (but they are still in my garage).
Either way, when a shop sometimes recognizes you level of business and tosses you a cheap item (like 50 cents or less) to you, it's nice and kind of them.
bluemonte0709
Jan 8, 2010 10:00 PM
6Kwatt06
Nov 8, 2009 11:33 PM
One Dark SS
Feb 11, 2009 06:16 PM
White05LT
Aug 12, 2008 09:02 PM
RIVER RAT
Jun 19, 2006 12:57 AM
