6th Gen ('00-'05): just a scratch right
Old Jun 26, 2014 | 08:03 PM
ROBF's Avatar
Default just a scratch right
well this has turned into a pita,using duplicolor cant get the clear coat
right.its running on me I think I am not waitting long enough for paint to dry.
Old Jun 26, 2014 | 08:48 PM
? looks like the dent is still there ????
Old Jun 26, 2014 | 10:18 PM
ROBF's Avatar
Yep
its a birthmark.Once its shined up I am done
Old Jun 26, 2014 | 11:17 PM
Once you wet sand and buff it should look fine. The fact it is on the bottom helps to hide it a lot. You will probably be the only one to really notice it anyway.
Old Jun 27, 2014 | 08:04 AM
Did you wet sand it between coats? What grit did you use to take it down with?.. The clear probably ran due to you didn't wet sand the base coat... or did you? Did you bake it dry ..with the sun or a lamp between coats?
Was it wet outdoors/raining? Humidity also effects the paint process.
What type of primer did you use? Did you happen to wipe each coat after sanding with de natured alcohol or Lacquer thinner?
Why didn't you pull and back fill the dent?
Its the little things that greatly improve the results.
Old Jul 1, 2014 | 06:46 PM
ROBF's Avatar
Had enough went to the body shop.fixing the dent painting the door quarter panel
and re clear coat.
Old Jul 1, 2014 | 07:05 PM
I had a friend that was painting a spoiler for a 96 Monte which was Red, he purchased the paint at his local NAPA store. oops! that was a mistake? He fought it until he gave up and let the body shop do the work. They used a different brand paint and it worked right the first time.
Good Luck with your details!!!!!!!!!
Old Jul 1, 2014 | 07:10 PM
and re clear coat.
Glad your getting the dent fixed..
Old Jul 2, 2014 | 05:21 AM
ROBF's Avatar
I should have my car back Friday.I will post pics.I wont ever try something like this again.Thanks everybody
blackmonte781
Sep 14, 2011 08:46 PM
thomasnchy
May 8, 2008 09:01 PM
LnLSS06
Apr 24, 2008 10:29 PM
Endo
Feb 20, 2008 12:48 PM
Sciggy
Mar 2, 2007 01:18 AM
