6th Gen ('00-'05): How to repair High Sport ground effects
Old Jun 29, 2019 | 10:27 AM
DAVESS2002's Avatar
Default How to repair High Sport ground effects
Hi, has anyone figured out what kind of plastic they used to make the High Sport ground effects? A couple of the retainers for the mounting clips are broken on mine. I'm trying to find out what kind of glue would stick to this flexible plastic or if a plastic welder is a better option to fix it permanently.
Old Jun 29, 2019 | 01:09 PM
Glen01SS's Avatar
Try Q-Bond with reinforcing powder. Its available at most auto parts stores. I took my front to a specialist in the mid 00's and he tried 3 times to repair this corner and the bottom tab. A friend had some Q-Bond 4-5 years ago and we tried it (on the car) and its paintable. I would recommend using some plastic mesh as an additional reinforcement. Let us know if it works, I have at least one broken fascia tab and want to restore it next year.
Old Jun 29, 2019 | 03:49 PM
Is it the clips that snap on the ground fx? Or is it the ground fx itself that broke?
Old Jun 29, 2019 | 06:59 PM
DAVESS2002's Avatar
Hi Maniac, it is the plastic inside the ground fx that holds the clips under the door that broke off. Here's a photo.
Old Jun 29, 2019 | 07:01 PM
DAVESS2002's Avatar
This is how it should be. Not sure if the Q bond will stick to this kind of plastic but it's worth a shot.
Old Jun 30, 2019 | 11:16 PM
Thanks for the pics, that does clear up the issue. That is a challenging one. I don't know if a glue is the route to take or perhaps a plastic welder.... I am sure a good body shop guy can give some ideas.
Onion39
Sep 30, 2015 07:53 PM
03redSS
Mar 26, 2013 05:12 PM
iMuf
Mar 5, 2013 08:36 PM
Sanjay Collins
Mar 5, 2013 10:32 AM
