Drivers side window
check gmpartsdirect look up year model in partsPlease select a corresponding number from the illustration below to view the details of that part.1) Gm Gm Right2) Insulator3) Insulator Rivet4) Sealing strip Right5) Channel Right6) W/motor W/motor Right7) Motor Back8) SpringDescriptionYearMSRP PriceYour PriceChannel Right
95-99 $279.28$171.36
Channel Left
95-99 $324.72$199.24
Before proceeding with check out, please confirm part number with our customer service at
cat.and view breakdown....
Channel Left 95-99 $324.72$199.24
Before proceeding with check out, please confirm part number with our customer service at cat.and view breakdown....
pull the door panel off and soak the track and ALL the moving parts with PB blaster. my '96 jumped out of the door once and my '97 had issues as well, everything gets crapped up and rusted up in the window mechinisim. lubing everything up should help ALOT
if you need help on how the door panel comes off, moderator MRL390 posted a great thread under the "how to" section.
tekboi
Dec 6, 2010 06:25 PM
