Drivers Side Window won't roll up(monte carlo 2002)
Old Dec 6, 2010 | 06:25 PM
tekboi's Avatar
Default Drivers Side Window won't roll up(monte carlo 2002)
I have a Monte Carlo 2002 model. And the power window on my drivers side doesn't roll up anymore unless I punch the window switch. It rolls down just fine, but has a problem rolling up. The last time I tried to roll it up it wouldn't do it at all. I had to remove the entire door panel and find the door switch. I tapped the switch real heard with a hammer. And now it's working(barely). But now i'm afraid that it will screw up again. And I found a replacement switch at autozone, but I don't want to replace it until I'm %100 sure that it's the switch.
How can I check to see if it's the switch or if it's a bigger problem?
Jester_20
Aug 24, 2014 02:29 PM
rjo98
Aug 15, 2011 10:36 AM
needasmoke24
Feb 19, 2011 08:42 AM
paudemge
Oct 15, 2010 07:05 PM
sarti8054
Feb 15, 2010 07:03 PM
