Drivers side window
Old Feb 17, 2011 | 10:32 AM
needasmoke24's Avatar
Default Drivers side window
1996 Drivers side window is falling out of the track, anybody have a breakdown of the door? its not in haynes...
Old Feb 17, 2011 | 04:52 PM
check gmpartsdirect look up year model in partsPlease select a corresponding number from the illustration below to view the details of that part.1) Gm Gm Right2) Insulator3) Insulator Rivet4) Sealing strip Right5) Channel Right6) W/motor W/motor Right7) Motor Back8) SpringDescriptionYearMSRP PriceYour PriceChannel Right
95-99 $279.28$171.36 Channel Left
95-99 $324.72$199.24 Before proceeding with check out, please confirm part number with our customer service at
cat.and view breakdown....
Old Feb 17, 2011 | 10:14 PM
irulesoha's Avatar
i had this problem a few times on my 99 pontiac. The track/motor that controlled the windows kept breaking, well, the small plastic piece that held the window kept breaking. Only like $40 each thoguh, but still a PITA.
Old Feb 18, 2011 | 10:17 PM
Default Thanks
At least I can get an idea of what this might be....
Old Feb 19, 2011 | 08:42 AM
skylark65's Avatar
pull the door panel off and soak the track and ALL the moving parts with PB blaster. my '96 jumped out of the door once and my '97 had issues as well, everything gets crapped up and rusted up in the window mechinisim. lubing everything up should help ALOT
if you need help on how the door panel comes off, moderator MRL390 posted a great thread under the "how to" section.
Furder2010
Dec 10, 2012 10:29 PM
tekboi
Dec 6, 2010 06:25 PM
paudemge
Oct 15, 2010 07:05 PM
sarti8054
Feb 15, 2010 07:03 PM
1995chevytech
Nov 11, 2005 11:51 PM
