Cleaning engine bay
Old Nov 18, 2012 | 03:17 PM
CDN85MonteCarlo's Avatar
Default Cleaning engine bay
Does anyone know what will remove rustcoating the spray on oily kind from the factory, that gets kinda gummy?? I removed a lot from the rad saddle area and striker area for the hood closure, with elbow grease lol...and a rag.
But I would like to tidy the underhood area up over the winter,
Gas has been suggested,,but not a good idea for me..propane heat in my garage and all..any suggestions on what has worked for you guys??
Thanks
Old Nov 18, 2012 | 03:26 PM
GOO GONE ... an SIMPLE GREEN .....works really well!
Old Nov 18, 2012 | 03:50 PM
Thanks! I am off to get some,Simple Green, thanks for the help
Old Nov 18, 2012 | 04:44 PM
01 Monte SS's Avatar
Simple Green worked great for me. I got a few spray bottles of it, covered up a few areas in the engine bay, hosed it down with some water, then I started spraying the Simple Green and tried to keep to worst areas wet for about 10-15 minutes, then I rinsed it and found that most had come off just from that. I went back and scrubbed some of the tough areas that didn't clean up easily. I have a 6th Generation so I'm not sure if has the rustcoating stuff you were talking about, my guess is probably not, either way it's a good product to start with. I'd recommend a well ventilated area though
Old Nov 18, 2012 | 07:02 PM
I use the LA Awesome orange from the dollar store for under the hood clean up. If you have some really dirty or grime areas the engine bright spray cleaner might work for you.
Old Nov 25, 2012 | 06:57 PM
Thanks!..goo gone works great with a little elbow grease, and Spray 9 to clean the dirty areas..ran outta rags tho...lol..more tomorrow...
Drivers side. and passengers for comparison
Attached Thumbnails Cleaning engine bay-dscf0113.jpg   Cleaning engine bay-dscf0117.jpg
Old Nov 25, 2012 | 07:11 PM
Looks Good..
Video
Oct 29, 2013 02:52 PM
tps221
Feb 5, 2013 06:36 PM
MONTE2000SS
Mar 21, 2012 09:30 PM
Cherry92
Nov 14, 2010 08:40 AM
saluteTOme
Jun 2, 2007 11:30 AM
