can you run dlr lights and fogs at same time?
Old Oct 3, 2012 | 05:57 AM
Murray137's Avatar
Default can you run dlr lights and fogs at same time?
Is there any way to do this? I'm trying to run my dlr lights/high beams with my fogs. I wanna run hids in my highs and fogs but keep the zxe bulbs in my lows for night driving.
Old Oct 3, 2012 | 07:40 AM
03SSLE's Avatar
Yes, you can use the DRL and fog lights simultaniously, but installing HIDs in the high beam location will lead to problems. The DRL are the high beams at half power. I don't think the HIDs would cooperate very well unless you rewired the entire high beam/DRL circuit.
Old Oct 3, 2012 | 10:22 AM
Yea that is a bad idea to run hids in the high beams, I tried that in my old car. This lead to major problems.
Old Oct 3, 2012 | 10:26 AM
I have hid high beams but its on its own harness with a new switch
Old Oct 3, 2012 | 11:22 AM
I don't understand your post....
You should put the 'ZXE' bulbs in your high beams, don't do high beam HIDs whether they're on their own switch or not, unless you run quad beams because they take too much time to light up and will leave you blind for some time.
I would run the low beam hids... 6000k or below, and then run fog lights on a seperate switch for the fogs, also 6000k or below.
Old Oct 3, 2012 | 02:04 PM
Murray137's Avatar
I would but only problem is I have the zxe lows. And it takes a different bulb for the high beams
Old Oct 3, 2012 | 02:39 PM
I'm not really suggesting this but you could buy the ZXE highs and return the lows in the high's packaging. But I didn't tell you to do that lol
You won't really need high beams once you get the HID lows. and if you ever do want to use the highs it's easier just to have a good halogen bulb in there.
Old Oct 4, 2012 | 05:29 AM
Murray137's Avatar
I'll look into it. Maybe ill just order the fogs and wait on the others. I was just gunna run hids in the highs since I don't use them. Was just going to run them during the day
Old Oct 7, 2012 | 10:28 AM
Murray137's Avatar
just a thought, but i dont use my highbeams at night, so if the light is running at 1/2 power could i put the hid's in my dlr and run them with out any problems? just as long as i dont use them at night?
Old Oct 16, 2012 | 07:49 PM
MonteLSV6's Avatar
Yes, if you wire your fogs to be independant on the switch, you can turn them on whenever you want. I have my AM fogs wired independantly from the lights to a switch. So everytime I run my car, I flip them on. Goes good with the DRL's
labnjab
31
Dec 2, 2010 08:46 AM
S_DAHM
Jul 8, 2009 10:59 PM
Yellow_Monte
Mar 17, 2008 06:09 PM
mickey
14
Oct 6, 2005 04:13 PM
mickey
May 30, 2005 12:39 AM
