2000 monte carlo template
Old Sep 22, 2009 | 09:16 AM
montegirl4ever's Avatar
Default 2000 monte carlo template
i have a 2000 monte and would like to add a spoiler, but my 2000 model does not have the holes in the trunk for one. does anyone have a template for a spoiler to help me out. thanks.
Old Sep 22, 2009 | 09:18 AM
When you purchase a spoiler (whether surfboard style [flat] or race-inspired [vertical]) they should come with a template for drilling the holes (usually it's a sheet of paper that you line up and drill through.
Old Sep 22, 2009 | 09:37 AM
i got the spoiler off a wrecked 2004 monte.
Old Sep 26, 2009 | 09:41 PM
Nuffy's Avatar
use some tape to mark off the center line of the trunk and the spoiler by running a full piece over both.
when your happy with the placement slice the tape between the spoiler/trunk.
pull off the spoiler and dab some paint on the end of each stud. if its a hole then put a bolt in and dab paint on that.
with it wet, line up the tape lines and set it down , make sure the bolts/studs contact. pull it off and drill where its marked
Old Sep 30, 2009 | 09:33 PM
Rell's Avatar
You should call up a local body shop. Because if you want it done you want it done right odds are the bodyshop has tackled many Monte Carlo spoiler replacements. I call a local shop when I got a spoiler from the yard. Cost me $50 to install at a local shop in my area.
Old Sep 30, 2009 | 09:43 PM
only 50 bucks to put on, damn i might do it then haha
Old Oct 1, 2009 | 10:12 AM
Rell's Avatar
Yeah it should be in that price range. Because if you buying the spoiler from a yard of the same color and just getting it put on shouldnt be much...all you basically is paying for is labor to measure and drill like 4 to 5 holes in your trunk. But it will be more if you getting one painted and put on.
03Monte
Jun 29, 2011 11:16 AM
mistiksky
Jun 23, 2010 04:40 PM
04Intimidator04
May 23, 2009 07:25 AM
Cloud_Master
Jul 9, 2008 12:23 PM
te100
Jan 29, 2006 05:31 PM
