starter solenoid location
Old Aug 25, 2012 | 07:28 PM
tps221's Avatar
Default starter solenoid location
where is it guys i see the starter i get a single click and the battery is fine and its not the security this time
Old Aug 26, 2012 | 08:16 AM
03SSLE's Avatar
The solenoid is mounted on the top of the starter motor. Follow the positive battery cable to the starter and you'll find it. The cable bolts to the front of it. Before replacing it I'd check the connections at the battery and solenoid making sure they are clean and tight. Then take the starter in and have it tested under load. If the starter checks good it's possible the positive battery cable has hidden (under the insulation) corrosion/oxidation that's creating resistance. A new cable may solve your problem.
rmorman
Oct 24, 2013 06:32 PM
mekoku
Feb 27, 2010 10:05 PM
mrl390
May 31, 2008 11:48 AM
2003supersport
Apr 25, 2008 11:54 AM
2003supersport
Apr 25, 2008 12:50 AM
