starter solenoid location
The solenoid is mounted on the top of the starter motor. Follow the positive battery cable to the starter and you'll find it. The cable bolts to the front of it. Before replacing it I'd check the connections at the battery and solenoid making sure they are clean and tight. Then take the starter in and have it tested under load. If the starter checks good it's possible the positive battery cable has hidden (under the insulation) corrosion/oxidation that's creating resistance. A new cable may solve your problem.
3rd Gen ('78-'80): Starter Solenoid for Summit SUM-G1660 Mini High-Torque Starter
rmorman
Oct 24, 2013 06:32 PM
2003supersport
Apr 25, 2008 11:54 AM
2003supersport
Apr 25, 2008 12:50 AM
