Montecarlo=big v6+small hp
Old Dec 7, 2007 | 04:10 PM
  #31
Cowboy6622's Avatar
Default RE: Montecarlo=big v6+small hp
yeah... we never got a good baseline because we couldn't get hte gear ratio to set right... i don't know, its hard to say what the car has.... this guy primarily tuned Corvette's and LS1 Firebirds and the such... said he VERY rarelly did Monte Carlo's....
Old Dec 7, 2007 | 05:21 PM
  #32
I remember you telling us that after you got the dyno. I think when money permits, you should try again somewhere else. I think you should be getting more than 150-something horses.
Old Dec 7, 2007 | 05:27 PM
  #33
couch's Avatar
Couch, if you wanted to get a great deal on a 3800 S/C, email ed morad and see what he can do for you. If you really aim to port, etc, then you may as well buy used, and build it the RIGHT way, ya know? Not to mention most 3800 S/C run less than 1200 bucks for the entire engine, alternator, etc...
WHERE??? i'm assuming you mean used motors. i think i might take a gander around a local scrap yard. lol the GMPP motor i was looking at is $4000 and turn-key. (once again cost +10%, the list is closer to 5k) and comes with a warranty. but with the NA mods i plan on doing it would be a useless warranty anyway.
Old Dec 7, 2007 | 07:27 PM
  #34
ExplosiveSoundz's Avatar
Exactly. Warranty only applies if you keep it stock. Look on ebay, and also email GTPED@msn.com. His name is Ed Morad. he is the KING of salvage stuff for the L67. I would go used. Bore it over .10", put new forged pistons and ported heads, and away you go. =)
Old Dec 7, 2007 | 08:42 PM
  #35
couch's Avatar
ORIGINAL: ExplosiveSoundz
my mouth watered when i thought of that thanks for the info dude.
Old Jan 17, 2009 | 07:51 PM
  #36
Is anyone else tired of having decent sized displacement (3.8l) for a v6 and such little hp. Personally, I m getting tired of getting blown out by those foreign cars with smaller engines with lost more hp!
Like you said- its an older engine, and is probably one of many reasons it was phased out. Back when the series 2 3800 first came out, 200 bhp was just about right as far as V6 midsize cars go. When you figure the series 2 3800s have been out since the mid 90s, and its 2009 (almost 15 years old)- its pretty obvious why it seems behind on technology and such. The other thing is once GM decided to consolidate its V6's to the 60* global engines, it stopped putting resources into 3800 development.
The other thing is, you have to consider what the engine was designed to do. Having a high revving, high peak HP engine is not really the goal in an engine that is destined for police/taxi/fleet use. I'm sure they were more than content with achieving mediocre power in return of an extremely reliable engine (which the 3800 has proven itself to be).
Also, you have to consider the price range of the cars that these HO V6's are going in- a 350Z, caddy cts, etc are in a higher price bracket than the cars the 3800s were going in.
For example, I had a litttle bout with a 2007 niassan 350z the other day, and he blew me outta the water, of course. I have the bigger engine, but his ride has a 3.5l pushing 300hp.
Honestly, for the power, they aren't that crazy fast. A top swap and some cheap bolt ons would've at least made the race even. I beat one of the ~280hp, older 350z's by about a car with my basic bolt on GTP.
Anyone else disheartened my this current trend!?
IMO, you really just need some engine mods. Sure its not cutting edge technology, but its cheap to mod- and if you want to keep up with the more technologically advanced vehicles- you're either going to have to buy one, or mod yours. A lot of people swap in the 3800 (even NA) from all kinds of various GM V6's and I4's just because of the huge aftermarket for it- you just need to exploit that.
Reviews are made before GM is complete with the line. Go look on the side of your drivers door of your car. 2042kg, or 4,502.
If you actually put your car on a scale- even in street trim- I'd bet you'd find it in mid-upper 3000s. A lot of wbodys that have basic track prep are landing in the 3600lb area, so I imagine a street car with full gas and no weight reduction shouldnt be more than maybe 3700-3800 lbs.
Well then I'd say the non supercharged 3800 guys are just screwed... You're right.
Actually, with how cheap used turbo/csc kits have become, and with how cheap it is to do an L67 top swap- they're nearly as well off as someone who started supercharged to begin with.
plus i plan on buying the supercharged 3.8 crate motor from GM anyway.
The crate engines are way overpriced. x2 on going used. Actually- it looks like you've got an L36- 3800 NA as it is, why don't you just mod that?
mine only put like 156 to the wheels... so who knows. maybe mine is one on the low end, who knows.
That sounds about right- most L36s seem to do on average 160whp. Add in variances in engine wear & tear- and weather conditions at the time, and you can see some difference there. Plus, engine dynos like the mustang always dyno a good deal lower than dynos like a dynojet- thats why its hard to compare dyno numbers, unless you're doing changes and back to back runs.
Rated engine HP, is not the BHP.
You mean rated engine HP is not the WHP (wheel horsepower)? The rated HP on the window sticker should approximate the car's engine's brake horsepower at the crank.
Thats nuts- has to be about what the car is worth. The 3800s are reliable enough that if you can find one with decent mileage (still see a lot pop up under 75k), that you can save thousands of dollars going used. Not to mention, you could buy a whole used GTP for that much.
Or save the money on a bottom end rebuild- stick with the stock bottom end, and put those thousands of dollars into making more power up top.
mousehousemoparman
Sep 19, 2011 12:10 PM
erik2282
Apr 27, 2009 04:32 PM
vipermann114
Jul 1, 2007 10:06 AM
turner_dtp
Sep 20, 2006 05:08 PM
h4x0rz
Feb 16, 2006 01:40 PM
