low oil after 2k
There can be some simple causes for the oil loss. Are you seeing any puddles/drops on the ground?
Best/easiest/cheapest oil leak is a oil pressure switch. About $10 and 5-10 minutes to change, right on the front of the engine.
You should also inspect the "valley" of the LIM gaskets. Sometimes those can seep oil out on the 3100. If the engine has not been cleaned in a while, a good degreasing could be in order.
mechanic knows its the rear main seal and oil pan gasket he's told me to bide my time until it was worth doing because it will be costly because the way the car is he'll have to pull the motor to do it
TMoney
Aug 18, 2013 02:37 PM
StanzManianDevil
Feb 22, 2009 11:28 PM
