location of recharge port ac
Old Apr 7, 2012 | 04:26 PM
tps221's Avatar
Question location of recharge port ac
well with my moms sable its right there and sticks out like a sore thumb. looking at my car its no where to be seen so seeing as it should heat up fairly soon in mass i figure i should have ac that blows cold this summer. i wanna do the recharge myself with a kit
Old Apr 7, 2012 | 04:46 PM
tps221's Avatar
I think i found it theres a black cap just behind my airbox
Old Apr 7, 2012 | 06:15 PM
I am not 100% sure but I think the recharge kit will only fit on the input line.
Old Apr 7, 2012 | 09:30 PM
Rellsun's Avatar
yeah if I remember corrctly its under the air box. lou is right it will only fit on the input line so you'll know if you have the right one. if its not that one I think the other is right near the compressor under the car.
Old Apr 7, 2012 | 10:02 PM
mousehousemoparman's Avatar
It is going to be on the suction line. If you locate the compressor there will be two lines. One will be large and the other one small. The small line is your discharge line and it will go directly to the condenser coil in front of the radiator. The larger line is the suction line and it will do to the evaporator which is in the air box. Follow that line and you will find the service port. If your system is empty then you have a leak (usually a stone hit the evaporator). For the system to work properly or at all you need to fix the leak, replace the filter dryer and put the system in a vacuum to remove all moisture from the system before recharging it.
Old Apr 8, 2012 | 12:52 AM
Rellsun's Avatar
There ya go. ^^ nailed it.
Old Apr 8, 2012 | 10:27 AM
Thanks for the tips, i was thinking about checking the charge on mine since its cool but not ice cold. The system was without a compressor for who knows how many years until i bought the car so i might have a small leak somewhere.
JaxJim
Jul 28, 2013 05:05 PM
jjsj10
Jul 9, 2008 11:13 AM
seth_06
Jun 26, 2007 07:45 PM
SophicSage
Jul 24, 2005 03:29 PM
