horn went out on the way to work
Old Aug 2, 2013 | 12:01 PM
tps221's Avatar
Question horn went out on the way to work
Was driving to work and went to use it and nothing happened it never squeaked out but I have yet to check the fuse as I'm assuming that'd be the mostlikely cause. Is there any other common causes I should check if the fuse is a-ok?
Old Aug 2, 2013 | 02:17 PM
Mike6208's Avatar
if the fuse is ok, i would check the contacts on the horns or the horn itself went out, when i had my 05 impala, i went threw about 3 horns because the rain and snow got under the bumper and rusted them out, not sure where they are placed on your monte, and my 01 monte i haven't had long enough to know if they have the same issue.
Old Aug 2, 2013 | 02:21 PM
Could be a relay..or the horn its self, Or in the steering wheel... ie bad loose connection
Old Aug 2, 2013 | 03:14 PM
Horn broke, watch for finger lol!
I've had the fuse pop before on other cars, change it and no more issue. Don't over complicate it, check the fuse, if it's popped, change it, test horn through out the week, if it keeps working no issue.
Old Aug 2, 2013 | 04:31 PM
My wife's 2005 Impala SS , I had to change the horns 2 times they quit..
The horns are in the same place on Monte's & Impala's ..
You can check the horns with a jumper wire .
Old Aug 2, 2013 | 04:39 PM
Let us know when you check your fuse...
Oh, I think I'm low on gas, do you think I should read my gauge > b-4 my car stops ? (LOL)
I do hope it's only your fuse & I thank all our member's that took their time to help you & others that may have a horn on their Monte that isn't working...
It's all good > Good Luck
Old Aug 2, 2013 | 05:39 PM
tps221's Avatar
Just having trouble getting to the fuse as the cross brace is in the way and one of the bolts won't budge. It never ends Lmao.
Crusader SS
Nov 18, 2011 09:21 PM
00'MonteSS
Apr 28, 2011 12:59 AM
nlewis44
Dec 15, 2010 07:57 PM
gothkid
Jul 24, 2010 02:48 PM
monte carlo 3831
Jul 9, 2009 09:03 PM
