> Driving a 740-horsepower electric `ride <
Old Apr 5, 2013 | 02:25 AM
Arrow > Driving a 740-horsepower electric `ride <
First Drive Review
<hgroup>2014 Mercedes-Benz SLS AMG Electric Drive
Driving a 740-horsepower electric anomaly. WoW, plug me in
</hgroup><!-- Gigya Social Share Floater -->The Mercedes-Benz SLS AMG Electric Drive boasts a 120-mile range and 738 horsepower, but don’t believe for a minute that you can enjoy both at the same time. When pushed to its full potential, the electric SLS won’t make it two laps around the 12.9-mile Nürburgring Nordschleife. This great conundrum—manage the battery range or exercise the car’s muscle—makes the great power of the SLS ED sort of, well, a limp proposition.
But who are we kidding? Those that can afford the $500,000-plus electric SLS will have people to worry about range anxiety for them. When deliveries begin later this year, the Electric Drive will be a very quick, very fun novelty toy—batteries included—for fewer than 200 well-heeled Europeans. (There currently are no plans for U.S. sales.) For Mercedes-Benz and AMG, the electric gullwing is a research test bed exploring the future of electric propulsion and high-performance vehicles.
Quick to Discharge, Slow to Charge
The 60-kWh lithium-ion battery pack and the software that manages it were developed by the Formula 1 experts at Mercedes AMG High Performance Powertrains. The 1208-pound pack contains 864 South Korean battery cells encased in a carbon-fiber box that acts as a structural element when bolted to the SLS’s aluminum space frame. HPP’s experience with F1’s Kinetic Energy Recovery System (KERS) was key to extracting big power from the battery, but the engineers didn’t make any strides when it comes to recharging the puck. Unless your garage is wired up like a public charging space, a full charge takes 20 hours—and that’s with 220 volts.
<table class="default" border="0" cellSpacing="0" cellPadding="2" width="429"><tbody><tr><td vAlign="top">
</td></tr></tbody></table>With four electric motors making 185 horsepower and 184 lb-ft of torque each, the total output of the electrified gullwing tops even that of the SLS AMG Black Series. Yet asking for all 738 lb-ft lacks the expected drama. The Electric Drive is undeniably quick off the line—we estimate 60 mph arrives in 3.7 seconds—but you won’t hear a chirp from the tires. That’s because torque is routed through fixed-ratio gearboxes that cover the entire speed spread, from creeping up to a stoplight to hitting the governor at 155 mph. To add some theater to the otherwise silent electric-car experience, AMG pipes a sci-fi soundtrack through the SLS’s eleven stereo speakers. “Idling” creates a whirring warble, like a UFO landing in a Warner Brothers cartoon, and there are similarly fantastical sounds for start up, acceleration, cruising, and braking.
Because the four-wheel-drive electric SLS has driveshafts where the gas-powered car’s front springs and dampers reside, AMG engineers redesigned the front suspension. The control arms have been replaced by a multilink setup and the coil-overs are mounted horizontally and actuated by pushrods. Other chassis changes include an electrically driven hydraulic steering pump (rather than a belt-driven unit) and standard carbon-ceramic brakes. Shift paddles behind the wheel adjust how aggressively the regenerative braking cuts in when you lift off the accelerator.
Hey, Everybody, Watch This!
The electric SLS’s primary party trick is a function of the four electric motors that power it. With each motor dedicated to driving a single wheel, the Electric Drive’s computers have precise control over the forces that make a car change directions. Accelerating and braking each motor independently of the others turns this 4700-pound brute into a ballerina. The level of torque vectoring—what AMG calls “Torque Dynamics”—can be set to one of three modes. In Comfort, the SLS Electric Drive can’t hide its 900-pound surplus over the gas model. The electric car is reluctant to change directions and the steering is sluggish. With the body always a step behind the wheels, the SLS feels more like an S-class than a half-million-dollar sports car.
</td></tr></tbody></table>Switching to the most aggressive setting, Sport Plus, affects a transformation unlike any adaptive suspension or torque-vectoring differential we’ve ever experienced. Turn-in is defined by Lotus-like immediacy. The body moves perfectly in sync with the wheels and the driver’s intentions. The steering is prescient, and yet the four-corner torque control means you also influence your heading with the right pedal. If you underestimate a corner, simply squeeze on the throttle to tighten your line—not to induce oversteer but to increase the yaw moment. The outside wheels accelerate, the inside wheels slow, and the Gullwing tucks in, darting for the inside. This four-wheel torque vectoring redefines the expression “steering with the throttle.” And while it’s unlike any car we’ve ever driven, this is the kind of electric car we can easily get behind.
Something to Look Forward to
The hyper-exclusive, ultra-expensive SLS AMG Electric Drive is an anomaly in the world of battery-powered cars. It’s too radical to serve as basic transportation and its range-limited battery keeps it from being a real track toy. Instead, its purpose is to serve as a development bench and proving ground for using smaller multiple motors rather than a single large motor. If the idea of dedicating a motor to an individual wheel becomes common practice, we’re looking forward to a future of hybrids and electrics. View Photo Gallery
Old Apr 5, 2013 | 02:33 AM
First Drive Review
2013 Jaguar XF and XJ 3.0 AWDJag builds a couple of Arctic cats.
AARON ROBINSON | February 2013
<!-- below are all possible cases for btns in each listing (some commented out for design purposes-->VIEW PHOTOS (16)READ FULL STORY
<!-- btns -->
First Drive Review
2013 Lamborghini Aventador LP700-4 Roadster200-MPH Windburn: Three-quarters of a Bugatti Veyron 16.4 Grand Sport at one-quarter of the price.
DON SHERMAN | February 2013
<!-- below are all possible cases for btns in each listing (some commented out for design purposes-->VIEW PHOTOS (63)READ FULL STORY
<!-- btns -->
First Drive Review
2014 Kia Forte SedanKia's fifth-generation compact sedan makes a strong bid for a bigger slice of the pie.
TONY SWAN | February 2013
<!-- below are all possible cases for btns in each listing (some commented out for design purposes-->VIEW PHOTOS (33)READ FULL STORY
<!-- btns -->
First Drive Review
2014 Mazda 6 2.5LMazda parlays Shinari and Skyactiv into a much sweeter 6.
<!-- below are all possible cases for btns in each listing (some commented out for design purposes-->VIEW PHOTOS (31)READ FULL STORY
Other Stories You Might Like
<iframe style="width: 1px; height: 1px; display: none;" id="ob_iframe" src="http://widgets.outbrain.com/nanoWidget/3rd/comScore/comScore.htm"></iframe>
<wbr><style type="text/css">.voterDiv .ob_bctrl{display:none;}.ob_pdesc IMG{border:none;}.AR_1 .ob_what{direction:ltr;text-align:right;clear:both;padding:5px 10px 0px;}.AR_1 .ob_what a{color:#999;font-size:10px;font-family:arial;text-decoration: none;}.AR_1 .ob_clear{clear:both;}.AR_1 .ob_amelia{background:url('http://widgets.outbrain.com/images/widgetIcons/ob_logo_16x16.png') no-repeat center top;display:inline-block;width:16px;height:16px;vertical-align:text-bottom;margin-bottom:-2px;padding:0px 5px;box-sizing:content-box;-moz-box-sizing:content-box;-webkit-box-sizing:content-box;}.AR_1:hover .ob_amelia{background-position:center bottom;} .AR_1 .ob_container{width:100%;position:relative;overflo w:hidden;}.AR_1 .strip-img{width:134px;height:82px;border:none !important;margin:0px !important;display:block;padding:0px !important;}.AR_1 .item-link-container{text-decoration:none;}.AR_1 .strip-rec-link-title{font-size:13px;font-weight:normal;line-height:16px;}.AR_1 .strip-rec-link-source{font-size:12px;line-height:16px}.AR_1 .strip-like{padding-bottom:4px;font-size:14px;line-height:16px;height:20px;font-weight:bold;}.AR_1 .item-container a,.AR_1 .item-container a:hover,.AR_1 .item-container a:visited{border:medium none;text-decoration:none;}.AR_1 .ob_video{border:medium none;position:absolute;top:5px;left:5px}.AR_1 .ob-rec-link-img{position:relative;}.AR_1 .wbr:before {content: \"\200B\"} .AR_1 .ob_container_recs{width:100%;position:absolute;}. AR_1 .ob_container_recs A{display:inline;direction:ltr;text-align:left;}.AR_1 .ob-text-content A{width:100%;padding:0px 0px;}.AR_1 .ob-text-content{padding-top:6px;}.AR_1 .item-container A.ob-text-content{display:block;}.AR_1 .ob_container_recs .item-container{float:left;direction:ltr;width:136px;mar gin-bottom:300px;padding-right:5px;}.AR_1 .ob_container_recs .ob-last{padding-right:0px;}.AR_1 .ob_container_shadow_outer{position:static;width:1 00%;}.AR_1 .ob_container_shadow .item-container-shadow{position:static;overflow-x:hidden;width:0px;float:left;direction:ltr;}.AR_1 .ob_container_shadow .item-container{width:136px;visibility:hidden;float:left } </style><style class="ob-custom-css" type="text/css">.AR_1 .rec-src-link {display: none;}</style>
2015 Acura NSX - Photos
(Car Reviews - 2011 Car Reviews and 2012 New Cars at Car and Driver)
2007 GMC Topkick Ironhide
(Car and Driver Video)
1968: Tunnel Port Ford Mustang vs. Chevrolet Camaro Z/28
Old Apr 5, 2013 | 08:07 AM
03SSLE's Avatar
I think Benz/AMG is in too much of a hurry getting this car to market. Poor battery life, poor mileage and the admission that it is still a 'rolling test bed'? Well, at least it has a 'space' frame.
'the Electric Drive will be a very quick, very fun novelty toy'
I think that pretty much sums it up - a toy for the elite to proudly display in their driveway. With a full recharge taking 20 hours at 220v that's probably where it will spend the majority of its life. 500K for a lawn ornament...
Old Apr 5, 2013 | 08:33 AM
Thanks `Mike for your post/thoughts I agree it's a very Rich Persons Auto Toy 4-$ure.....It's hard 4 me to believe that there are people out there that will pay a half a million $'s 4 the above
I'd rather purchase 10 new 2014 Corvettes & share them with my `friends *go 2 a track & have some fun 4-Real
1984monte
Jan 11, 2014 04:10 AM
Dec 29, 2011 06:05 PM
JaxJim
May 12, 2010 02:57 PM
BeachBumMike
Aug 7, 2008 05:29 AM
malletboy
May 20, 2006 01:02 AM
