Transmission howling/whining
Old Nov 25, 2018 | 12:42 PM
rlgii's Avatar
Post Transmission howling/whining
Hello. My 2006 LT, 3.5L with a 4T65-E has a progressive howl/whine that increases in volume and pitch with the increase of speed (started off quiet, months later it is very loud esp. at ~60 - 80 mph).
Any thoughts as to what it could be?
Can this be repaired with the transmission still in the vehicle?
Old Nov 25, 2018 | 04:01 PM
Smile
What does the Trans fluid look like? RED or Brown? Check at the Auto parts house or Walmart for trans mission additives. Lucas Oil maybe? a Howl sounds like its dry or the fluid is bad. Bearings also? Have you taken it into a Trans shop to get a diagnosis ?
Old Nov 25, 2018 | 07:46 PM
rlgii's Avatar
The fluid is a nice pink color, not burnt, and no bubbles. It was recently rebuilt (like 16 months ago) and the shop that did it wants $80 to diagnose it. I believe this wasn’t rebuilt correctly, should last at least 3 years.
Old Nov 26, 2018 | 06:25 PM
Hearing the terms "howl" and "whine" make me suspect the wheel hubs.
Does the sound change if you steer to the left or right? Has anyone lifted the car in the air and inspected the wheel hubs for play in them?
Old Nov 27, 2018 | 04:59 AM
rlgii's Avatar
No, no change when the wheel is turned either direction.
And both wheel hubs and drive axles were checked.
Old Nov 28, 2018 | 08:13 AM
How many miles are on the car? I am suspicious of hubs or bearings as well. That would explain why it gradually gets louder as speed increases.
Old Dec 1, 2018 | 06:06 AM
rlgii's Avatar
303,xxx and she’s well maintained. I’ve replaced wheel bearings, know what they sound like when bad. Replaced the right CV axle this year, the left is original and seems in good condition. The transmission was rebuilt 07/2017.
Old Dec 3, 2018 | 07:59 AM
Possible that its' the tires then at this point?
Sounds like you've checked the usual culprits. I also would have leaned towards hubs from the first post. Were the rear ones also checked?
Kph
May 27, 2018 08:40 AM
SSilver
Mar 30, 2016 09:34 PM
bossross
Dec 22, 2015 05:14 PM
Smblanchette
Dec 31, 2013 05:41 PM
iMuf
Oct 15, 2013 02:23 PM
