Running into transmission issues
Old Oct 11, 2013 | 07:57 PM
iMuf's Avatar
Default Running into transmission issues
Hey guys, so today I got up early to go and have my car inspected and go have it re-registered. So I backed out like I normally do and when I put it in drive I gave it some gas and it reved almost like it was in neutral and then it slammed into gear and started going forward. And then when I got up to the light up by my house it did the same thing where I gave it gas and nothing happened and then it slammed into gear and started moving forward. I'm going to be getting a TEP trans so I could care less if this one goes out, I just don't want it to go out while it's still in my car. Any ideas on how to prolong the life of it for another couple months until I can get a TEP trans? The trans fluid was changed about 10 months ago.
Old Oct 11, 2013 | 08:59 PM
SOUNDS LIKE ITS LOW ON FLUID....
Try a fluid filter change..
Old Oct 11, 2013 | 09:22 PM
iMuf's Avatar
The filter was changed as well, could it be time for a new one anyway? And I will check the trans fluid tomorrow as well. Thanks
Old Oct 12, 2013 | 03:44 AM
JC Colon's Avatar
Sounds like low fluid level to me. How does she shift into the other gears? Are they hitting Hard too?
I can't wait to get my income taxes. Those $$$ will be invested in a TEP Trans for my car too. Till then, I did a fluid and filter change with a quart of Lucas Trans Fix. It helped. Not 100% But at least it was better than it was before!
Old Oct 12, 2013 | 07:40 AM
iMuf's Avatar
It actually shifts perfectly fine which is why low fluid level didn't come into my mind. But I will check that before I go to work today.
Old Oct 15, 2013 | 12:18 PM
iMuf's Avatar
So I checked my fluid today and all looks good. It's also color wise still pinkish redish. Any other ideas?
Old Oct 15, 2013 | 02:23 PM
dbaldwin's Avatar
Try some sea foam (I think that's what its called) trans tune, iv heard it helps, it doesn't thicken the fluid like others. It didn't harm my transmission when I tried it and stopped my stuttering from a start.
SteveCZ28
20
Mar 23, 2015 08:49 PM
RandySavage
Sep 15, 2013 10:28 AM
nighthawk626
Jul 6, 2010 10:56 PM
Cschlue
Mar 21, 2010 08:12 AM
samuelkowal906
Aug 26, 2009 05:43 AM
