Supercharger oil
Old Aug 16, 2015 | 07:47 PM
hstrasser's Avatar
Default Supercharger oil
Hello everyone,
I have a 2004 Dale Jr and I just recently replaced supercharger oil in mine. Yes it did smell nasty..
I don't think I tightened the giant black hex screw tight enough. I think I had to use a little T27 screw driver. I can only tighten it so much by hand. When I drive and pop my hood while I'm parked somewhere, I inspect it. And some seems to be leaking very slowly out the sides of the hex screw. Is this because its not tight enough? I fill it to the filler neck just at the bottom of it. I dont think i overfilled.. Did I? What could be causing it to leak?
Old Aug 17, 2015 | 10:45 PM
nitehawkjcb's Avatar
Mine was tightened with an allen wrench, no leaks here. I'm guessing it's overfilled a little.
Old Aug 18, 2015 | 05:04 AM
hstrasser's Avatar
Is that suber bad? Can this cause engine damage or anything? Do you recommend taking some out? I only used two 4 oz bottles and ended up taking out an ounce or two
ssjr
Aug 14, 2015 02:28 PM
AwesomeSS
Mar 14, 2009 02:42 PM
AwesomeSS
Feb 20, 2009 06:58 PM
MonteSScarl05
Feb 2, 2008 02:31 PM
