Questions based on performance(Supercharged)
yea there is alot of things you could do to get the loud exhaust, with or without mufflers, mine is an LS with an SS exhaust set up, a cherry bomb ressonator, magnaflow high flow cat, dual flowmaster super 44's and its LOUD.... loud enough to scare most mustang and camaro guys.
they take premium??? oh wow i did not know that at all, yeah i may just stick to getting an SS, insurance is already high for me because i am you. so is there a big differance between the supercharge and the SS??
my honest opinion i say trade your monte on a non sc 3800 then top swap it. by doing this it will keep your insurance down a little and also the non sc cars are cheaper than the sc cars. even after doing a top swap im bet it will still be cheaper. but if u dont feel comfortable doing the swap then i say just buy the sc 3800 from the start because by the time u pay someone to do the swap you will be spending more money.
A supercharger is a belt driven power adder and looks something like this:
Some 3800's come with a supercharger (either a Gen 3 Eaton M90, or a Gen V Eaton M90). The supercharged 3800's make a bit more power then the NA 3800's and have MUCH more potential modifying wise. If you're NA, you don't want to stay NA (been there done that).
No Series I, II, or III 3800 came with a turbocharger, so you will either have to do a custom build or buy a kit through a 3800 vendor such as ZZPerformance. If you plan on making anything more then about 300whp, then you should go turbocharged due to the cost of modifying a s/c 3800 vs a t/c 3800. Going turbo is expensive at first, but after that you could make anything from 300whp to the ZZP drag car's 870whp.
If you're NA and plan on doing either a top swap or going turbo, you will HAVE to have your PCM retuned (dyno-tuned is optimal), and you shouldn't run anything less then 91 octane, but E85 is the best fuel bang for the buck.
Hope that helps. If you have anymore questions, feel free to ask.
Welcome to the forums and happy modding!
A turbocharger is an exhaust driven power adder and looks something like this:
also the turbo is ran off of exhaust so its free power making more horsepower, but the sc is ran by belt from the crank so it actually takes a little power to make more.
if you are looking for all out major hp then turbo is the only way to go. a stock engine with a intercooled turbo kit can get you around 300hp with a good tune, it would take engine work to see this on an sc build.
to go turbo it does cost more but the end results are worth every penny. i also suggest intercooling with the turbo kit from the start.
ok, thanks, this is alot of info
one question, what does NA mean? and could i do all this with my 3400 series? i may decide to just keep my car due to insurance diffrence and gas.
but can i do all this to my LS?
N/A stands for Naturally Aspirated, meaning the engine is responsible for bringing in the amount of air it does, there is no outside help, such as a supercharger or turbo.
There aren't "kits" for your 3400 like the 3800, so doing that yourself is going to require all custom piping.
vincenti
12-04-2013 12:56 PM
carlm54stl
06-15-2013 05:39 PM
2005, 53, 53l, carlo, chevy, interchange, ls, modifing, modify, monte, ss, supercharge, supercharged, supercharger, supercherger, year
