please help
Old Nov 25, 2019 | 12:30 AM
Rodriguez Rodriguez's Avatar
Default please help
I just purchase a 06 Monte carlo and have a problem I can't figure out when I getting some speed starts to missing but I push the gas pedal deeper and goes away, I replace spark plug the cables and one coil I replaced the cat I I put some treatment in the gas rank and no luck but the funny part about it is that only does it on d when I sift it to 3 goes away then my idling its to low have any one gone through this problem before?, thanks for your help
Old Nov 25, 2019 | 06:21 AM
Smile
Maybe you need to replace the fuel filter, while you are at it the air filter might be needing replaced as well.
Old Nov 25, 2019 | 09:13 PM
Default 06 Monte Carlo ss
ya bro I just did it today and didn’t help I test the fuel pump pressure. And is good.
Old Nov 26, 2019 | 08:32 AM
Jeffs02rwdSS's Avatar
If you believe it's missing the easiest and cheapest route is to scan the computer for miss-fire information and see which cylinder is the issue. To me it sounds like a coil failing. I had similar issue only under acceleration . Good luck
Love my Monte
Jun 1, 2011 01:40 PM
Ryans93'
15
Dec 20, 2010 11:57 AM
02montecarlo
Jul 14, 2010 08:08 AM
echolmberg
Sep 8, 2008 08:07 PM
mitch2115
Jun 25, 2008 10:45 PM
