I'm from Southern Il.
Old 07-07-2010, 11:39 AM
Bodean46's Avatar
Unhappy I'm from Southern Il.
Hello, I have an 02 Monte Carlo SS that i bought the wife new in June of 02. It now has 246658 miles on the original motor and transmission with out ever having any major work othe than belts, hoses, ect. done. This a.m. i went to start it after sitting all last week ( Took Harley to Mich. for the week) the key will not turn. I'm assuming with the miles the tumblers have worn out. My question is how do you get it out of Park if the key wont turn? Any help will be greatly appreciated. Thank You.
Old 07-07-2010, 11:53 AM
Hi BoDean, & Welcome to the Monte Carlo Family.
WoW, close to a quarter of a million miles on your Monte
Yes, sounds like it needs a new ignition ?
Check back to see what other member's did.
Below are some links to check `out, and one from our forum.
Good Luck.
Automotive Recalls and Technical Service Bulletins for 2002 ...
05-00-89-078B FEB 08 Fuel System - GM Fuel System Treatment PLUS(R) Info. ... 06-02-35-005 FEB 06 Ignition - Key Stuck In Ignition Switch/Won't Turn ... 04-08-47-003 AUG 04 BCM - Security Lamp ON/No Crank/DTC's Set ...
www.alldatadiy.com/TSB/10/021007gn.html - Cached - Similar
Automotive Recalls and Technical Service Bulletins for 2004 ...
www.alldatadiy.com/TSB/10/041007fd.html - Cached
Show more results from www.alldatadiy.com
Find TSB for your 2002 Chevrolet Monte Carlo V6-3.8L VIN K. online
Free Technical Service Bulletin and Recall Titles for 2002 Chevrolet Monte ... 08-07-30-027, JUNE 2008, A/T - No Movement in Drive or 3rd Gear ... 05-00-89-078B, FEBRUARY 2008, Fuel System - GM Fuel System Treatment PLUS(R) Info. .... 06-02-35-005, FEBRUARY 2006, Ignition - Key Stuck In Ignition Switch/Won`t Turn ...
tsb.govwebs.com/k-vin-v638l-carlo-monte-chevrolet-2002-13259.html - Cached
Technical Service Bulletins - 2005 Chevrolet Monte Carlo V6-3.4L ...
Free Technical Service Bulletin and Recall Titles for 2005 Chevrolet ..... 06-02-35-005, FEBRUARY 2006, Ignition - Key Stuck In Ignition Switch/Won`t Turn ...
tsb.govwebs.com/e-vin-v634l-carlo-monte-chevrolet-2005-15431.html - Cached
Show more results from tsb.govwebs.com
Key stuck. 2004 Chevy Monte Carlo. (Ignition Chevrolet Monte Carlo ...
May 4, 2010 ... 2004 Chevy Monte Carlo. When I put my car in park the key won't turn all ... Bulletin No.: 06-02-35-005. Date: February 28, 2006. TECHNICAL ...
answers.edmunds.com/question-Key-stuck-2004-Chevy-Monte-Carlo-97851.aspx - Cached
2002 Monte SS stuck ignition key - Monte Carlo Forum - Monte Carlo ...
3 posts - 3 authors - Last post: Feb 4, 2009
2002 Chevrolet Monte Carlo Technical Service Bulletin (TSB) ... 06-02-35-005 FEB 06 Ignition - Key Stuck In Ignition Switch/Won't Turn . ...
www.montecarloforum.com/forum/showthread.php?t=12045 - Cached
Get more discussion results
My 2003 Monte carlo won't allow the key - JustAnswer
Mar 10, 2007 ... Bulletin No.: 06-02-35-005. Date: February 28, 2006. TECHNICAL. Subject: ... 2002-2005 Chevrolet Monte Carlo. Condition ...
www.justanswer.com › Chevy - Cached - Similar
Old 07-07-2010, 12:00 PM
Bodean46's Avatar
Thanks for the info. Guess i'll call a hook to take it to the garage. Broke my back in 01 and can't get in under dash anymore.
Old 07-07-2010, 02:45 PM
Welcome, and hope someone can give you an idea of what to do.
I have no idea, good luck.
Old 07-07-2010, 03:21 PM
The Popcorn King's Avatar
Welcome to the forum man.
Old 07-07-2010, 06:55 PM
Welcome to the site! I hope you get your Monte running again!
Old 07-07-2010, 07:06 PM
SpinEm_90's Avatar
Heyy! Welcome to the forum! Good luck getting the monte running again =)
Old 07-08-2010, 07:49 AM
MAMONTE's Avatar
Definitely sounds like the ignition is shot.
Wow, man, that is pretty awesome that you've gotten so many miles on your Monte, with so little problems! Good luck in getting it going again, and putting more miles on it! LOL.
Old 07-08-2010, 09:41 AM
RickAKATed10's Avatar
Photobucket
Welcome.
Old 07-08-2010, 11:04 AM
Bodean46's Avatar
Finally got key to turn and drove it to the shop this a.m. Let someone who knows the car fix it. He's been the only one to touch it since the first oil change @ 3000 miles.
Quick Reply: I'm from Southern Il.
