Headlight Relay
Old Jul 30, 2014 | 02:00 PM
WendyCGP's Avatar
Default Headlight Relay
healight Relay "Replacement." 2001 chevy monte carlo ss
where is it located? I have no Low beams
Old Jul 31, 2014 | 05:46 AM
WendyCGP's Avatar
I was able to change the delay relay, but cant seem to find where the headlight realy goes, i know it's at the drivers side (inside) fuse panel, but I do not see it- It says Inside Cover?? I need help please.
Old Jul 31, 2014 | 06:10 AM
Hi Wendy,
Click below link & explore prior light issues.
Check back on your thread to see what our MCF Expert member's post. (I'm not one of them)
Monte Carlo Forum - Monte Carlo Enthusiast Forums - Search Results
Click above link > Good Luck
It's from our MCF Search Engine above.
Old Jul 31, 2014 | 06:38 AM
WendyCGP's Avatar
Thanks
Old Jul 31, 2014 | 11:19 AM
WendyCGP's Avatar
Didn't help much. I know where the fuse panel say's it is, but I just don't see it!
It's like finding the power steering fluid cap- its way down and under. cant see it - Have to feel for it. CRAZY!
Old Jul 31, 2014 | 01:56 PM
Hi Wendy,
Don't give up. I hope that one of our expert member's still see's your post > problem & can help..
Behind the fuse box on the drivers side. there is a clip on the top of the fuse box that retains it in the car. It runs on 2 rails on the left side of the box. Depress the clip and pull out the entire box. On the back side are 2 relays the smaller one is the relay for the headlights. It is also the same relay as the horn that is in the engine compartment. Swap them to test.
Check out the below
Old Aug 2, 2014 | 06:32 AM
WendyCGP's Avatar
Default Fuse Holder
Still having a hard time to pull out - the silver Clip only held the yellow thing in place, I see no other clips. I might try to access from under. if I can get down on the floor in a weird position...
Old Aug 5, 2014 | 08:24 AM
WendyCGP's Avatar
OK with help, I was able to change the Relay - but still no low beams, a friend seems to think it's in the directional switch. There is power at the bulbs when tested. so the switch will be changed next. and I hope thats it! I can't afford all these fixes.
Old Oct 30, 2023 | 09:36 AM
mwolt's Avatar
Default Where is relay?
I have the same issue and I’m hoping it’s the relay. Where was the relay located? Also, what was the issue?
MJClemm
Dec 12, 2012 02:21 AM
DavinGee
Jul 29, 2012 10:02 PM
cjp_ejp30
Dec 18, 2007 07:55 PM
odessadude
Oct 7, 2007 08:44 PM
ccbee
Nov 29, 2006 01:46 PM
