Headlight Relay
Old Dec 13, 2009 | 10:26 PM
DavinGee's Avatar
Default Headlight Relay
I recently installed HIDs headlights for both low & high beam. Unfortunately, the low beams don't stay on when I turn on the high beams. I got a relay kit to turn both low beams & high beams on together but it does not work because the lights tie in with the BCM. Has anyone figured out a way to overcome this problem?
Please let me know.
Thanks!
Old Dec 13, 2009 | 10:28 PM
DavinGee's Avatar
Oh. It's a 2001.
Old Dec 14, 2009 | 10:02 PM
Paul1965's Avatar
Please let me know.
Thanks!
Try this courtesy of BBEngineering a few years ago. Got the same mod on my list of to do things this winter. And as it says, do this at your own risk!
Old Dec 14, 2009 | 10:05 PM
when you do the high beams is it just like installing lows? is there anything special you have to do?
Old Dec 20, 2009 | 11:28 PM
DavinGee's Avatar
Yeah...high beams & low beams are the same to do.
Old Dec 21, 2009 | 10:11 AM
okay, even tho theres a daytime running light?
Old Dec 21, 2009 | 12:13 PM
TheMonteMan's Avatar
why do you want to run the hi and low at the same time? just curious.
Old Dec 21, 2009 | 04:58 PM
jimbo7's Avatar
i can only imagine having high and low beam hid's on at the same time is like having the sun crashing towards you. it doesn't make sense to have both running the same time, unless you still have halogens.
i have low beam hid's now, but plan on getting the highs done in the next few months. the only problem i see is having you highs running all day and prematurely wearing out, since technically you drl is gone. isn't there a company that makes something to safely turn off your drl without messing with the wiring?
Old Dec 24, 2009 | 12:59 PM
DavinGee's Avatar
Well I installed HID's in high & low beams. When I want to turn on the high beams it takes about 10 seconds for the bulb to heat up. So for that 10 second period I have no lights. That's why I'd like the low beams to stay on when I turn on the high beams.
Old Dec 24, 2009 | 04:26 PM
jimbo7's Avatar
that's true. i don't use my highs (halogens) anymore cus by the time they reach full brightness i need to turn them back off.
