2004 SS Power Steering
Old Jun 15, 2019 | 11:52 AM
BarryU's Avatar
Default 2004 SS Power Steering
I have a 2004 SS Hearing the power steering groan. Do i remove the sensor to check the fluid level or is this a shop issue?
Old Jun 15, 2019 | 01:39 PM
Jeffs02rwdSS's Avatar
Power steering pump is located on engine close to the firewall. Remove the car and check the fluid level. Good luck
Old Jun 15, 2019 | 03:27 PM
BarryU's Avatar
Hey Jeff
Thanks for the welcome. Yes I looked for the location in my manual. It shows the reservoir passenger side in front of the alternator. with a cap as one would expect. To my dismay it is not there. There are no other reservoirs on the fire wall. Transaxle dip stick is all. There appears to be a space large enough for a reservoir where noted in the manual. The only device in that space is what appears to be a solenoid. I am baffled at this point.
Old Jun 15, 2019 | 04:59 PM
The pump is underneath the alternator and is rather hard to see and get to but is accessible. If you can't find it bring it to a oil change shop they can help you.
Old Jun 15, 2019 | 09:25 PM
BarryU's Avatar
Hey Jeff
Thanks for your reply and I am sorry I didn't get back with you sooner. I found it earlier by a picture i found. I guess they put it in a different place on the 3800. as opposed to the 3.4. Any how I removed the radiator overflow and it was fairly simple. 14 years and never any issues. Great car. only needed a small amount of fluid to get to the lower level line. I will be keeping an eye and ear open. Once again I appreciate your help.
Have you any experience with the remote amp. That manual volume control doesn't respond and I don't seem to be getting the power output from the amp.Both 12 volt sources are present at the amp.I dont have an electrical wiring diagram. I wanted to check the sensor for auto resistance or miliamp signal. I tried to get in touch with Panasonic to no avail
Regards
Barry
Old Jun 15, 2019 | 10:41 PM
Sorry I can't help you with the amp , but a few members here probably can point you in the right direction. I would suggest starting a new post to get beat chance at a quick response.
BarryU
Jun 15, 2019 11:27 AM
Zeke
Sep 15, 2016 08:51 AM
Sparky-88
Dec 22, 2011 07:34 PM
2003supersport
Oct 30, 2008 10:32 PM
Gr4v3_7
Dec 6, 2006 05:34 PM
