2001 SS High Idle Cold
Old Nov 11, 2013 | 06:57 PM
johnsora1's Avatar
Default 2001 SS High Idle Cold
When I start the car for first time everyday it increases rpms. I try to hold back throttle on throttle body but cant. I turn it off and restart it and its normal, can anyone help with this? Thank you
Old Nov 11, 2013 | 07:51 PM
owens91's Avatar
mines does that too, i actually think its normal to get that high idle when you do the morning start. after 5 mins it whines down to its normal idle
Old Nov 11, 2013 | 08:56 PM
It may start and idle a few RPMs, but it should be quick, as in under 5 seconds. You may want to check out the IAC and ensure that is clean and working properly.
Old Nov 11, 2013 | 09:04 PM
johnsora1's Avatar
Yes, I cleaned throttle body and IAC, but it just keeps climbing to 3,000+ rpms if I dont shut it off. Im thinking its the IAC...
Old Nov 14, 2013 | 08:52 AM
johnsora1's Avatar
Without paying to put it on a computer, what would be your best guess, IAC or MAF? Anyone?
Thanks!
Old Nov 14, 2013 | 09:09 AM
dbaldwin's Avatar
Thanks!
Does the car stall? Could be a plogged cat. Get inder the car after a longer drive and look for a glowing CAT. Also check for a plogged air filter (the paper filter or the metal one going into the intake manifold) I'd check filters before I'd chwck sensoes as they are more likely to cause this extreme of a reaction.
Old Nov 14, 2013 | 11:30 AM
Not sure a clogged cat or plugged air filter would cause HIGH idle....
High idle is typically a result of too much air or a vacuum leak. The IAC helps control the idle, so that could be to blame, could also be a vac leak somewhere. Can easily check for a vac leak with a can of starting fluid (mist it around the vac lines, listen for the idle to change and if it does inspect that location further for the problem).
Old Nov 14, 2013 | 11:32 AM
dbaldwin's Avatar
Iv seen high idles beacuse the car is trying to pull more air in through a plogged filter. The CAT was a less likely possibility. Also check what jason says cause he knows more than me though. Haha.
Old Nov 14, 2013 | 12:04 PM
JC Colon's Avatar
I would have your MAS checked. Mine did the same thing and I had to hold the gas peddle for about 1 minute to keep it running when the motor was warm. I put a new MAS in, problem solved!
obeymyego
Mar 24, 2015 10:15 PM
Harleyldraper
Aug 8, 2010 01:02 AM
vegav6
Apr 14, 2007 09:00 PM
mtmer1
Oct 24, 2006 09:54 PM
shawner
Mar 8, 2006 03:27 PM
