'03 3.8 Engine Squeal Hard to Track Down--Please Advise
Old Sep 24, 2012 | 06:07 AM
nice that is was an easy fix!
Old Sep 24, 2012 | 07:39 AM
good job.....gladyou found it was as simple as the pcv system.
Old Sep 24, 2012 | 07:50 AM
03SSLE's Avatar
Originally Posted by Osiris
Ok, so after some self-humbling I took everything out and realized that the repair shop put the O-ring on the valve before inserting it, so that is what I did. That's wrong. You put the valve in its cradle, then the O-ring goes around it in a nice little recessed area...THEN the spring rests nicely on top of the O-ring. Then, the sensor goes on top as usual, no prob.
Good to hear you found the problem, but the o-ring is supposed to be on the pcv valve prior to installing it - just like the shop did it (see pic). With it sitting on top of the valve there is a chance it will become dislodged and your vacuum leak may return.
Old Dec 29, 2012 | 01:44 PM
Osiris's Avatar
Thank you for this info and diagram. It's the end of December and I haven't had any problems, but I think I will go buy a new seal and put it in the correct position. Thanks again!
Old Dec 29, 2012 | 03:48 PM
congrats!
jford61
Aug 11, 2013 07:50 PM
mcadamsp
May 22, 2013 08:47 PM
phoenixdude24
Sep 25, 2010 08:59 PM
02WhiteHighSportSS
Feb 9, 2008 04:05 PM
tez
Mar 12, 2007 12:48 PM
