Won't start
Won't start
98 monte carlo LS, turn the switch on but won't start, replace the ignition/starter switch, still nothing. Can use a screw driver on the starter soleniod and it will start and run for about 5 seconds, then shuted off. Will start right back up but again for 5 seconds
Did you run the security relearn after replacing the ignition switch? If not I would do that 1st.
Here is a link to the relearn procedure https://montecarloforum.com/forum/fwd-tech-guides-95-07-62/security-re-learn-procedure-8598/
