Wont Accelerate..
Old Sep 23, 2010 | 06:40 PM
1998Carlo's Avatar
Default Wont Accelerate..
Hey I have a 1998 Monte Carlo LS its the 3.1
It has trouble accelerating and usually wont go past about 2000rpm but has gotten worse to where it wont go past 1500rpm.
This happens even when the car is in park/neutral..
Need help thanks!
Old Sep 23, 2010 | 09:15 PM
seawolf18's Avatar
Is the check engine light blinking? If it is then you are having a ton of misfires, which would be something wrong in the ignition system. It could also be that the cat is plugged, or you are not getting enough fuel pressure from a weak fuel pump\plugged fuel filter. I would also test the fuel pressure, and see what it is reading too.
Old Sep 23, 2010 | 09:22 PM
1998Carlo's Avatar
No check engine light is on, however it didn't do it all the time, but lately it has gotten worse and happens more frequently
furcioelbraveado
Mar 4, 2012 04:11 PM
powerguy5051
Feb 24, 2012 06:56 PM
piyushbali
Aug 15, 2010 11:28 AM
adoublearonn
Jul 18, 2010 02:46 PM
corrado1979
Oct 5, 2009 01:22 PM
