Wire Question
Old Nov 4, 2008 | 09:07 AM
draxxis's Avatar
Default RE: Wire Question
The remote starter works fine from about 40 feet away.. I've only tried it at that distance.. So I don't know if that is what it is or if it is some other wire.. They wouldn't have needed to cut this wire for any reason at all because it didn't need replaced.. I just needed the plastic on the a-pillar replaced.
Old Nov 20, 2008 | 12:13 AM
draxxis's Avatar
I found out what the wire is for.. It is originally for OnStar.. When they were using an older system, this wire was used as an antenna.. Well, now that the line goes through the little black box that sits on top of my car, this antenna isn't needed anymore.. So what they are supposed to do is cut the wire & push it back into the pillar & put a cap on the spot where it connects to the wire on the windshield.. They didn't have any caps, so they left the wire connected there and pushed in the tail so that it looked like it was connected.. The Service Supervisor apologized for any confusion and kept on apologizing that the tech didn't inform him that the service was done.. Guess its in a TSB or something that came from OnStar itself.
Old Nov 20, 2008 | 06:38 PM
kweef's Avatar
hmm i knew it was an antenna i thought the radio antenna was on the front and the onstar was on the back
Graves53
Aug 30, 2013 06:43 PM
Murray137
Oct 20, 2012 08:13 PM
Teacher
Oct 9, 2008 08:55 PM
cali2000ss
May 16, 2008 09:34 PM
jayturk99
Feb 26, 2006 01:30 AM
