1988 SS
Old Nov 17, 2008 | 08:12 PM
Retired's Avatar
Default 1988 SS
Hello !!
I am a brand new member and just found this forum . I am glad that I did.
I have an ' 88 SS with much modified 305 with OEM electronic Q-jet and computer. I have been entertaining the thought of replacing the present electronic carb and distributor . I would replace with std Q-jet and HEI . One of my concerns is the overdrive/lock up 200 transmission.
I would like to hear from people that have done this , their experiences and sugestions .
Thank you
Old Nov 18, 2008 | 11:26 AM
Retired's Avatar
Default RE: 1988 SS
Thank you Knightfan !! Glad to be here !! Retirement is a challange, But, someone has to do it !!!
Old Nov 19, 2008 | 03:43 PM
88ss408's Avatar
Default RE: 1988 SS
if you switch over to a hei distributor and non-cc carb you will have to get a lock-up kit b&m makes them along a couple other aftermarket companies .
and with that change you can remove all the ecu harness and smog stuff to make the engine bay alot cleaner looking !
Old Nov 19, 2008 | 07:22 PM
Retired's Avatar
Default RE: 1988 SS
88SS408 !!!
Thank you much for that info !!! You just put a big smile on this retired gummer's face !! Yee ha .....
I will get to looking for that harness unit . the Big Boy SS has been put away for the winter......
Thanks again for your time !!
John
Old Nov 20, 2008 | 06:30 AM
88ss408's Avatar
Default RE: 1988 SS
i hear ya on that mine is gone in hibernation also !
but yeah do the carb and distributor swap over the winter and you will see a big difference when srping time comes around make sure your carb is tuned right and what hei are you going with ? just a stocker ?
Old Nov 20, 2008 | 07:58 PM
Retired's Avatar
Default RE: 1988 SS
88SS408 ,
I will probably install just a std vacuum HEI . I have a Q-jet off my corvette or a spread bore Holley that I can use for a carb . Presently the engine won't start as it floods viciously and I don't want to wash the internals anymore . I hadn't started it for a year and I probably created my own problems.
John
jessentexas
Oct 4, 2006 08:40 PM
97silverls
Sep 5, 2006 09:41 AM
metal4ever
Jul 12, 2006 08:51 PM
ngc414
May 10, 2006 10:34 AM
metal4ever
Apr 25, 2005 09:45 AM
