wipers out of sync
I noticed on my 2002 Monte that the wipers stop mid windshield when on the delayed setting. They work fine on high or low. Is this a bad wiper motor or some other problem? Any help appreciated.
http://en.allexperts.com/q/Chevrolet...per-sync.htm#b
:rolleyes: "Your problem is probably a bent tab on the motor bracket or a loose crank arm" Check the infor in the above link to see if it helps. Also check back to see what other members will post that had a same or similar problem with their wipers...Good Luck |
On top of Dino's post I would take a look at the wiper motor pulse board module.
I had this issue with one of my other GM vehicles and this module was the fix. |
