windshied arm
Old Jun 12, 2010 | 08:55 AM
willie 03 ss's Avatar
Default windshied arm
im having a problem with the driver side windshield wiper the drivers works good the pass wont move at all tried tighten the bolt it will work for a day or so then just flop and wont work again
Old Jun 13, 2010 | 10:40 PM
Sliver's Avatar
I'm not sure if the arms are interchangeable but if they are you could swap the two sides and see if that helps. Or it could tell you to get some new hardware, most likely.
Old Jun 13, 2010 | 10:49 PM
lucian*91's Avatar
the grid they slide onto could be warn off. that or its warn off on the inside of the arm itself. does the nut spin when they go or does the whole thing stay still?
Old Jun 14, 2010 | 03:16 PM
the nut moves the arm just doesnt
Old Jun 16, 2010 | 01:06 AM
lucian*91's Avatar
yeah, its warn down then, take it off and see if the teeth are warn off the wiper blade or the piece it connects to and replace accordingly
Old Jan 1, 2012 | 08:04 PM
MONTE CARLOS's Avatar
im having this same problem how do you take off the bolt
Absolutpolack
Mar 10, 2013 03:58 PM
l0gitech87
Aug 6, 2011 11:11 AM
kc2kth
Mar 30, 2010 07:46 PM
foxxtrot
Jul 9, 2008 07:42 PM
scc24540
Aug 20, 2007 07:26 PM
