Window switch
Old Apr 22, 2014 | 03:07 PM
teddyballgame13's Avatar
Default Window switch
Hello,
I took my 1998's door apart to put in a new speaker, which works nicely. However, now the window goes up fine, but not so fine down. I took the switch apart and if I play with it just the right way the window will go down, but with no consistency whatsoever. I'm looking to purchase a new power window switch on Amazon.com Is there anything I can do before I splurge the $40 needed? I did spray a little WD40 to clean the connectors. Any help would be appreciated. The passenger window works fine btw.
thanks,
Ted
Old Apr 22, 2014 | 04:37 PM
l67ss's Avatar
yeah id just go with a new switch, when they die they die. i swapped to an 05 monte pw switch in my 97
Old Apr 22, 2014 | 09:49 PM
Aaron0313's Avatar
ah so they're unlike the 2000-2005 PW switches where you can take them apart and clean them to restore function?
Old Apr 23, 2014 | 10:14 AM
vikesfan's Avatar
get a switch from a junk yard, they usually cost free.99, mater of fact, grab a couple.
the window switches are notorious for going out due to rain dripping on the inside and landing right in that switch area.
$40 for a new one, when i can get 3 for free??? your call.
side note, i didnt know or even think of the 6th gens switch fitting the 5th gens. pretty sweet if they do.
Old Apr 27, 2014 | 10:55 AM
Default Thanks!
Thanks for the comments, I put in the switch I ordered and the window worked like a charm.
thanks,
Ted
Harlan2012
Feb 6, 2013 01:39 PM
montecarloenthusiast
Jul 10, 2007 06:20 PM
schultzy
Dec 23, 2006 11:37 PM
schultzy
Dec 22, 2006 02:36 AM
montecarlo1995
Jul 6, 2005 05:06 PM
