wierd noise after repair work
so i j ust had some work done today to my 97 monte carlo, left rear wheel cylinder, and the motor mount was repaired. they also changed two tires and rotated those. well the guy drove the car around did some adjustments on one of the brakes, drove around again, and then gave me my car back.
after about 5 minutes of driving i started to get a loud noise, it sounds like its the left front, almost like when you stick something in a moving fan. any ideas? ill definitely be bringing the car back to them tomorrow morning thou to be checked out.
It cant hurt for you to check that you don't have a loose wheel. Pug a Lug Wrench on those Lug Nuts and make sure you'll be getting back there in one piece.
Having a loose wheen will do a number on how the wheel fist if you don't rectify the problem right away.
STUMPMI
May 7, 2013 08:20 AM
5th Gen ('95-'99): After my head gasket repair!
InfamousFlip
Mar 14, 2013 04:24 PM
InfamousFlip
Mar 14, 2013 04:11 PM
